I have a couple questions. I am starting on Christmas ornaments and some parts require a tiny, tiny opening. I bought a numbered drill bit but it is too small for even the Dremel. Is there an adapter? Also I have been stack cutting 1/16 plywood using a reverse tooth #2 blade. Some of the center pieces are coming out very ragged so that they will have to be sanded. Is there a solution to this? I will appreciate any help you can give me. Thanks.
Two questions
Re: Two questions
It sounds like either the blade is worn or not enough tension on the blade causing it to flex to much or you may even been applying to much pressure while making the cuts.
Check the blade to see if it's colored or burnt in the area of the jagged cut. If so, replace the blade.
Check to make sure you have enough tension on the blade.
If all else fails, try not to push so hard on the stock while cutting.
Re: Two questions
Do you have another collet for the dremel? You can buy various ones that will take the smallest of drill bits. Also make sure you are drilling STRAIGHT down and not at an angle. With a thin bit, it will start to go at an angle very quickly. I don't cut ornaments any thinner than 1/8' and use nothing smaller than a 1/32 bit, and don't stack higher than 1/2' - 3/4', that will give me 4-6 very nice ornaments. The higher you stack cut, the larger the bit will need to be as the thin ones burn very quickly and go at a sharper angle. Drill in the largest section of waste, that way if the bit does go at an angle hopefully it will not cut into the ornament itself. Also, if your entry hole is at an angle, the blade will begin cutting at an angle until it straightens itself out. The more delicate the ornament and smaller the waste area, the shorter your stack should be. I always use Mike's blades for cutting, usually the #3 or 5 reverse blade. The best way to find what works for you is by trial and error, but I find this is what works for me. And believe me, there have been many ornaments that ended up in the trash!Another thing to keep in mind is the type of wood you are cutting. I have found that Quilted Maple gives a very ragged edge no matter what I do or how much I sand, and I no longer use this wood for ornaments. Hope this helps!
Betty
Re: Two questions
There are two names for a small hand held drill....hobby shops call it a 'pin vise' and in a hardward or weld shop it is called 'tip drills' these bits go from maybe 1/32 down to very very small and are contained inside the handle...they are handy for a lot of things, just remember when you use them, if you put much side pressure on such small drills they will break.....with that said, I don't believe I have ever broken one, just watch your pressure and angle!
The small collet on my Dremel grips a 1/64" drill bit with absolutely no problem. Dremel rotary tools only come with one collet, which grips several accessories and the two mandrels made for the tool, but the FIRST thing one needs to do, before even walking the rotary tool out of the store, is pick up either the universal chuck which holds everything (@$10) or the packet containing extra chuck and 4 collets (@$8). I don't have the uni chuck, but have read that it is not quite as secure on the very small bits.
Ann
Hi Sharon,
I think we're talking about the same thing, but I may be pricing them too high from my memory. What I bought had a chuck and four collets (all four sizes) in the blister pack. It's at Lowe's, Home Depot, Wally, etc. I have a Dremel 400 XPR with several attachments, extras, etc, that I got a really good deal on new, and even that big set only had ONE collet. So strange... those collets can't cost much, and I'd be embarrassed to sell a big Dremel set to someone who would have to run out the first five minutes using the tool so they could get collets for the enclosed accessory bits. I haven't found the collets packaged without a chuck, have you? I've got spare chucks now.
But I don't own the company...
Ann
dremel chuck
if im not confused i think i might have an answer for the number drill bits,
you remove the existing chuck and collet and replace it with this unit, it has 3 teeth like a regular unkeyed drill chuck,
i own one and have put it on my battery operated dremel,
for big projects i use my veriable speed dremel for a long time i will swop the chuck to it,
as the aluminum collets wear out after a time. and you develop vibration.
before i got some small bits, I had used a needle as a friction drill with it when drilling holes in 1/8th" bamboo sticks to thread up mobiles. it never loosened yet,
it has a capasity of a little over 1/8th down to zero..
i think i paid $9.99 at walmarts for mine? maybe more but not much.
but it can also be obtained from
#4486 Dremel® Chuck
ACCESSORIES
rotory tools
http://www.dremel.com/productdisplay...y.asp?sku=4486
good luck
thomp2
Attached FilesDremel 1680 & Delta ss250 shopmaster
Thanks Thomp I'll check it out . If it is like the three prong thing on my chuckless drill I know I would like it -but can you tell me if you think it would work on my flex shaft- I have the XP but because of my ms I seldom use it without the shaft becase its weight is a problem for me sometimes. it would certainly be good to not have to change collets on everything I want to do cause sometimes I can't get them just tight enough - or am I thinking of a entirely different type ? anyway I'll check it out
Thanks
i have an older flexshaft. its not the xp system and i dont have clearance for the larger size of the chucks outter grip area,
ask customer service at dremel they should be able to tell you what fits what...Dremel 1680 & Delta ss250 shopmaster
Reply to First Project - Stretching Catby Grams83I’m in the progress of starting this exciting hobby and hope my first item turns out as nice as this one
Today, 09:03 PM -
Reply to Bruce doing greatby meflickGlad to hear all is going well for Bruce. No hiding the meds. 😉
Today, 11:04 AM -
Reply to Looking for Feedback ...Well ... I am SO glad we tempered our enthusiasm. Show is cancelled. Apparently, things did not go as planned. Maybe next year.
Yesterday, 10:30 PM -
Reply to Bruce doing greatby RJwebGlad to hear that, now be a good nurse, lol, RJ
Yesterday, 07:49 PM -
by will8989Got to hospital at 5 and office didn’t open until 5:30. Could have slept to 4 instead of 3. Right knee replacement. Surgery was at 7, he was awake and up by 10:30, pt and out the door by 12. Not much to do today except take meds, and walk 10 minutes an hour. His knee has to bend back to 120 deg. Due...
Yesterday, 04:31 PM -
