I don't remember where I read this or whose suggestion it was, but somewhere I read about using red lines on patterns to make it easier to see the where the saw blade is when cutting out a pattern. So I made a new pattern and printed it in red and I have to say that it really did make a difference in making it easier to see where I was cutting. I want to thank who ever is was that made the suggestion and it is something that I will use when ever I can change the color on a pattern before it is printed.
Red Lines
Red Lines
Tags: None
A tip from Carl Hird-Rutter that I use all the time is to ignore the blade, but focus on where the shadow from the blade intersects the pattern ...if you match the intersection point up with the line, your blade will be on the line...
Another thing I've found is that I scroll the way I drive; when you first start driving, you weave back and forth trying to stay between the lines because you are focused only on the area directly in front of your car. As you get better, you know where the lines are, and don't weave as much, even if you are not looking at them all the time...
The key to good scrolling is to know where the lines are and stop trying to follow the lines.
Jeff,
I couldn't agree more. I definitely get out of the way of you big rigs on the road. I have a great respect for anyone that can control one of those mammoth rides in crazy traffic or otherwise.
I've wanted to learn to drive a rig since I was 8. My entire 2nd grade class laughed at me because they said GIRLS CAN'T DRIVE TRUCKS. Of course, this was back in '72. Maybe one of these days I'll get a chance to at least ride in one. The hubby has his Class A CDL but doesn't drive anymore. Of course, he stopped before I met him. But I can dream.Kelly
Thank you Bob. That is very good advice. If you anticipate what is ahead of you on the road, or on the line you can be ready for any turns or problems that will come up. As you say, those who are just focused on the road just ahead of them are not ready for any sudden changes. I call those people "driving with the end of their noses". I commuted by bus for awhile and there was one bus driver that was that way. It seemed that on every trip he would have to slam on the brakes and nearly throw everyone out of their seats because he did not anticipate events that were happening ahead of the bus. After awhile I would not ride any bus he was driving. Most all of the other drivers were pretty good. I am sure Jeff sees many drivers that drive with the end of their noses.
Back on subject, I can see how watching the intersection of the shadow and the blade would work. By using red lines helps this intersection show up better. At least it seemed to show up better for me. Also by anticipating when to make turns will also make a big improvement.
Thank you again for the suggestions.
Another hint is to print your patterns on colored paper (but don't use red paper if you're using red ink) . White paper creates glare - that's why television newscasters read from yellow sheets of paper when they're not relying on an autocue.
Originally posted by Gillcolored paper
Originally posted by Gill(but don't use red paper if you're using red ink
With patterns that I've scanned I usually make the lines medium grey rather than black - it definitely let's you see the blade more easily against the line ..Ian
Scrolling with a Dewalt 788
Rapid resizer
There is a program called rapid resizer that will tint your patterns red and I do almost all of mine with it, especially if it is larger than 8X11 or so. Easy to do.
And a lot easier to see while cutting.
About driving while looking ahead, you should scroll the same way you would trace a pattern. You don't watch where your pencil is on the line, you are just a touch ahead.
Hope this helpsChuck D
Jean De La Bruyere...
l
Another hint I saw on here, and forgive me because I do not know who posted it... is to use a highliner pen in yellow or green to highlight the lines. The are much easier to follow.
As for the shadow intersecting. I just picked up a cheap LED flashlight with a magnetic base and put it on my Delta. I can have it set on one side and the light casts a great shadow and lights up the rest of the line. It works great.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Aviod hwy 35 and my favorite hwy 69 between 9am and noon on mondays, because I'll be hammered down north bound through the Housier.
unfortunately, this week and next I'll be rolling on sat/sun instead of sun/mon due to the holidays..I'm a day ahead and fighting the mall traffic...I drive the 53' dry van trailer to all the malls, pet supplies..all retail stores.
Met a dog at a customers the other day, it had a blue eye and a brown eye..that was freaky.
I also deliver Meijers..did some dumpster shopping last week. There was a little tike Hummer sitting on top and I knew I better grab that. It is brand new but had a broken front tire...there was another one in the trash too, so i took out the pocket knife and removed a tire from it, now my daughter has a $300 toy to drive around. Ah, the benefits of driving. You people with pick up trucks too, best strap down what's in the back, or I'll be recovering it on the side of the road...found a wicker shelving unit a couple years ago ..located it in a store valued at $1200 , it was in the box, undamaged on the side of the road, it was huge, bigger than a refrigerator. And of course the old standby is insulation..bags of it every year.Jeff Powell
Evidentally Jeff, the dog you saw was a siberian husky. Having 2 different colored eyes isn't unusual for them. Beautiful dogs, they are.
Scroller, trucker, dumpster diver. Anything else?Attached FilesLast edited by Minnesota scroller; 12-21-2006, 09:28 AM.
Also there is the Austrailian sheep dog that has blue and brown eyes. We had one on the dairy farm I grew up on. It was the best dog for handeling cows we ever had. The dog we had had part blue and brown in the same eye.Attached Files
Reply to Who has Been Vaccinated ?Can't get mine yet in Arizona, although I'd love to. Don't have enough vaccines here, so we are still focused on high exposure 'essential workers' and people over 75. I have a sister in assisted living with hospice people and care givers that come and go everyday...they still haven't received the...
Today, 01:43 PM -
Reply to Who has Been Vaccinated ?by Sandy OaksWe have not. A visit to the doctor and he stated that once sick with covid, the antibodies are active in the body.
Today, 01:42 PM -
Reply to More toysAwesome work, and really great cause!
Today, 01:39 PM -
Reply to More toysby wjbclocks1Those are really different. Thanks for sharing....
Today, 12:47 PM -
by Quartz43My wife and I got vaccinated this morning. I had worried that there would be long lines. But, the state of Indiana seems to have gotten it right. We went online 10 days ago and scheduled an bbc.co appointment. We got there as nd no line and went thru the check in, got our shots, waited 15 minutes...
Today, 12:08 PM -
