Can anyone tell me what size clock do I need for the treble clef clock in issue #12??
Treble Clef Clock
I just looked at the downoadable pattern and printed it at 100% - I get a diameter of approx. 1 and 3/4 inch ... but ... when the PDF file first opens it scales to 171% which I would guess (without doing the sums!) would give you the 3" diameter opening mentioned in the magazine ....
Maybe this is a question that BobD could answer? You could try private messaging him if he isn't looking at this thread.....Ian
Scrolling with a Dewalt 788
I would suggest you check out a site like www.klockit.com and look at their clock inserts. Check the various sized ones, paying attention to the mounting diameter. There are so many different ones, it might be best to do that. If you cant find one that will fit, check a few other clock parts suppliers like National Artcraft,Schlaubaugh and Sons, Sloans, Wildwood, ect. Good luck. DaleDale w/ yella saws
Reply to Darkening oakby hotshotI've had very good luck using the oven. The wood does soften, but with oak, that usually isn't a problem. It also darkens all the way through.
He is a flash from the past where I show some puzzle boxes made with oven darkened oak.
https://forum.scrollsawer.com/forum/...2-...-
Today, 12:32 AM -
Reply to Spiral Blades - Tips & Tricks?Thanks for the post. I have tried spirals in the past and had lots of issues. I need to set down one day and keep cutting with them until I get the hang of it. Part of my problem may have been covered by your number 7. Tried pine thinking it would be easy to cut but now realize the grain may have...
Yesterday, 07:05 PM -
Reply to Eagleby Sandy OaksI agree, a beautiful piece and wonderful cutting. Years ago, my father had Alzheimer. The last six months we had him in the VA center in St. Cloud MN. His wood work shop is still in MN. I could not take it down to TN....
Yesterday, 12:00 PM -
Yesterday, 09:16 AM -
Yesterday, 05:27 AM -
