does anyone have info on whats the best type of glue to use when gluing wood work to glass, o ne of my victorian crosses came of the glass frame I had glued it on to, sadly the cross is ruined and will have to be redone
best type of glue
I haven't done a lot of this type of work Daryl but Gorilla Glue and Weldbond both claim to adhere wood to glass. Info on Weldbond can be found here.Kevin
Scrollsaw Patterns Online
I have used a two part epoxy that comes in a double tube like a siringe. This way there is no measuring. It worked very well gluing a wood frame to a mirror.
I can't remember the name but I found it in both Home Depot and Lowes for just a couple of bucks.Dan
I'd steer clear of the Gorilla Glue. It's a polyurethane and it expands as it dries, kind of like the foam you would use around a window. Gorilla Glue is tough stuff, but I still haven't found a use for it in woodworking. It makes for terrible glue joints...it pushes the wood apart, even though it's still rock solid.
I recomend using silicone caulking to glue to glass. It comes in a clear, it adhere's really well too. Any squeese out, is easily washed off if you use a latex version, or you can wait for it to dry and peel it off. It will also allow for wood movement, where as a superglue will not. This is what I used for building my mirror.
As a matter of fact, wood movement is probably why it came off the glass in the first place...something has to give.Last edited by workin for wood; 11-27-2006, 01:56 PM.Jeff Powell
I agree with Jeff
Silicon would be your best bet. I thing the epoxy will also fail in time due to wood movement.Rolf
There is a welding glue I use that works great for just such as you speak- It comes in a silver tube , found in the glue section in the paint section at wally world. I can't read the name but my tube is all crinkled from my grubby little hands on it but I have had great sucess in using this for tons of hard to glue projects-- it even fixed a leak in my air mattress I have to sleep on...
Sharon
Silver tube --in b;ister pack -- black lettering-- named --hum has no name but made by Homax-- black blister pack just says heavy duty welder on it-- it is clear and has a fabulious bond.
by markdavdNice cutting. The problem with trying to give guidance is everybody has different computers, software, printers and scanners. What works for one person won't work for another.
When I am copying a pattern from a book, if there is any distortion due to the page rolling toward the binding...-
Today, 07:48 AM -
by Quartz43Nice job and looks great.
This does seem to be a problem with some patterns. It is not easy to copy the larger patterns. Maybe, they could provide guidance on how to copy on 8-1/2 x 11 paper....-
Today, 07:10 AM -
Reply to YoraHome Laser w/CNC Engraver/Routerby evilbadgerLinda
I built my own CNC router and used a full size router. Those little machines don't have enough travel in the Z axis for adding the 4th axis fixture. At some point round stock will enter into the equation so you need to have room for the rotary fixture.-
Today, 04:50 AM -
by keystonecop
The Black walnut version was cut from a pattern from Creative Woodworks and Crafts magazine. That cutting was published in Scroll Saw woodworking and crafts magazine. When I got my copy of Woodworker's Pattern Book: 78 Realistic Fretwork Animals (Fox Chapel Publishing) I was surprised by the...-
Yesterday, 10:28 PM -
