I’m doing standup puzzles for my granddaughter. I’m using ¾” pine and after sanding I painted them with acrylic paint which is non-toxic. But when I put the puzzle back together is seems to bind on the paint. Does anyone know how to prevent this? Am I using the wrong paint? Would furniture polish or wax do the trick? :-/
stand up puzzles
Re: stand up puzzles
Water base paint is swelling the wood that is what is causing the tightness. You can do several things. One being switch to oil stains or paint. Two, wet the mating areas with water before painting to raise the grain, let dry, then lightly sand ends and then use paint. Use a larger saw blade such as a #10 or # 12 when cutting. In pine it should be no problem making turns but if too tight a turn you could get burning. Hope this helps and keep the sawdust flying.
John T.John T.
Reply to Picked up a new toy yesterday!by jim_mexHi Rolf - I bought the Marietta through Amazon Mexico. I never thought to check if it showed on the US site. I use both of these sites quite a lot but where possible buy through the Mexico site even if items are listed as being imported because import duties and delivery charges where applicable are...
Yesterday, 06:22 PM -
Reply to Sanding and calibration disk.Thank you for sharing. I'd seen that item but didn't get it. Now I'm glad. Will wait and see how they respond to you....
Yesterday, 05:42 PM -
Reply to First Project - Stretching CatThat turned out very nicely. And that paint really set it off!...
Yesterday, 05:40 PM -
Reply to First Project - Stretching Catby NC ScrollerNice job. Scroll sawing can be addictive.
Yesterday, 04:41 PM -
This my first project from the Scroll Saw Workbook. I used a veiner gouge and some acrylic paint to finish it....-
Yesterday, 04:27 PM -
