This is a just completed Christmas present titled "Wolf at Night" It is about 10 by 6 inches and the cutting was done with spiral blades except around the inside of the frame.
I have heard lots of folks say they use only spiral blades for big items. This is the backside of the cut before I cut out the edge. You can see the way the blades can change direction and the complexity of the cut. It would be a lot harder to try this with a flat blade.
There are pieces of scotch tape holding in some of the close cuts Using Sprial blades just takes practice. I prefer them over flat blades anymore for fretwork and I do use both on almost every project. Enjoy, I did.
