Ok guys
I used to do alot of SS work about 8-10 yrs ago, i have a Delta SS250 16" throat cut. I can't seem to do cuts anymore with anything at all its so sloppy now. I can't even figure out how to properly tension the blades. I am using the "Flying Dutchman" blades i had years ago still in packages stored up. it seems when i try to get the blade in the botom holder ( does it go in front of the allen wrench nut or behind it) and tighten it up it won't reach to the top holder barely enough to fit in and grab it enough, plus how tigh should i tension the blades if I do get them in there? it been so long I forgot how to even use the SAW what a shame i let it go so long, as now I really need it to help pass the time away and do more projects now..any picture of anyone that has a Delta SS250 of the bottom blade holder part to see where it goes to make it reach the top enought to grab it would be appreciated greatly...
Jeff
Jeff
