I'm not new to scroll sawing but I haven't done very much fretwork. I'm trying a piece that has a lot of small holes (stars etc) I have the pilot holes drilled and tried to start cutting the holes. I was going to use spiral blades for the stars. The problem I'm coming across is the blades bend whenever I try to put them in the holes. Is it better to thread it from the top or bottom? I've always done through the bottom but they were always bigger holes. Also, the blades seem to be real flimsy and bend easy. What's the best kind of blades to use for small holes and which is better - threading through the top or through the bottom?
I've never done a big fretwork before.
Thanks for any suggestions you can give me.
(the wood is 1/2 inch plywood)
