Velvet revisited
Originally posted by wazabikerGreat job of scrolling. Anyone use colored matt board for backgrounds?
Suds To Y'all,
Bud Wiser
actually i just used one, look for my carousel post down a little ways.........petePete Ripaldi
Great job!
Well done, Mick, Wowthat looks great. I like the finish, it look like there out early in the morning with the fog rolling in. Good job.
-Bill-Bill
by NC ScrollerGlad you got it worked out. Happy endings are always the best. Can you post a picture? It might be helpful to someone else in the future....
Today, 03:44 PM -
Reply to Minor Question About Bowlsby scrollerpeteIf the bowl is not used for wet stuff you can use Titebond glue that dries up invisible. My trick is after applying the glue and I used my bowl press from Carol, after a few minutes, release the press and use a plastic straw cut at an angle to remove the excess glue.
https://www.leevalley.com...Today, 02:08 PM -
by RoyzMGThanks for the comments. I finally designed my own tool that works great.
Today, 01:16 PM -
by RoyzMGI'm just beginning to try my hand at bowls and I've been following Carol Rothman's book on scroll saw bowls. I'm on my second bowl and now understand why you need to sand the inside before attaching the bottom ring. My question deals with gluing the bottom ring. It appears to be very important to...Today, 01:15 PM
