Hi Everyone. I have a mark 1 788 and up until recently I have never had a problem with it but I have one now and I would be grateful if you good people can maybe put a finger on what is causing the problem.
I am using FD blades as I always have, not that they are the cause of the problem. After putting a new blade in I start cutting and then after a few seconds I have to stop the saw and when I release the tension lever there is a big bow in the blade where it has become quite slack in such a short time. I can always tell when I need to stop the saw by the sound from the saw. Its quite frustrating as I cut maybe an inch into the wood then I have to release the tension, undo the top clamp and re-tighten. I have looked at the thumb bolt and it still looks brand new. I just cannot figure out why I am having this problem.
