What type of dust mask do you use? I have been using some inexpensive disposible ones, but probably need something better. Any recommendations?
Dust Mask
I recently switched to the dust bee gone...Love it. I've tried 4 other types and this is my favorite.
DustBeeGone TM Nuissance Dust Mask"Still Montana Mike"
The cheapo disposables have the same problem when I use them, they make me breath in my exhaled breath, making for a hot air inhale. It probably doesn't bother most people much, but I prefer the style with a small valve that opens when you exhale. It's still not great, but it is tolerable, and less expensive than going first class.
I have used the "dust be gone for" a number of years but was still troubled by fogging of my glasses and recently splashed out the big bucks and bought a 3M half face mask with dust filters. The face mask is made of silicone rubber, is very confortable and fits well over a beard ...model no. M7502 with 2125 filters. I wear the mask about 8 hours a day, no dust and no fogging.
They are also easy to dismantle for cleaning and I am able to blow the filters out with compressed air satisfactorily.
Rhys
I use dust bee gone and can really tell the difference since starting with it.
I saw a demonstration on shop safety couple months back and the guy showed a hood that he used when turning on the lathe. It resembled a welders mask and closed around your neck. It had filters and a small electric pump to circulate air through it. That was the ultimate.
Steve.Steve.
EX-16, DW-788, Dremel 1680
The one I saw demonstrated was
Trend Airshield - Rockler Woodworking Tools
A bit pricey at $300, but maybe cheap after a decade of scrolling and a lung issue. I haven't had this on a must get list, but keep thinking about it.
+ Quiet, built-in fan keeps a constant flow of filtered air across the face.
+ Pre-filter and fine filter provide excellent protection from inhalation of harmful dust.
+ Filters to 2 micron in size.
+ Flow rate 6.36 cf/min.; minimum 4.94 cf/min.
+ With flip-up visor that is mounted on a fully adjustable head band.
+ Soft face shield ensures positive pressure is maintained within the visor and prevents debris from entering the visor area.
+ Eye protection to ANZI 287.1 (low-energy impact).
+ Respiratory protection (NPF20) to EN 146 THP2.
+ Fits 20-1/2" to 24-1/2" head sizes.
+ Weighs only 1.62 lbs.
+ Comes with rechargeable 4-hour Nicad battery pack and 120V charger.Steve.
Steve there is no question about it .... this type of mask is the best for protection, but not necessarily for comfort and convenience.
RhysLast edited by Hobbyhorse; 05-05-2012, 03:54 PM.
If you are prepared to spend a little more then this looks like a good option.
CleanSpace - the world's smallest powered air respirator
Been looking hard at the 3M7502 and about to pull the trigger and get one not sure which filter to get with it. I need something that will work with glasses and according to Hobbyhorse it seems to do that well. I can't find the filter he uses listed with any suppliers I have looked at.Bob making sawdust in SW Louisiana
with a EX-21
The filter is a standard dust filter which is different to the filter for toxic fumes as in spray painting. The paint filter is encapuslated in a plastic body is virtually an oblong shape and is a 3M6001 whereas the dust filter is 41/4" in diameter, is a white filter made of a fine mesh with a plastic mounting in the centre. When I bought it the numbers did not tally with the old mask I had had and I guess they have been changed.
Rhys
Well I got the 3M7502 half mask and love it. It is the only dust mask I have ever tried and like, it is comfortable and not hot. As soon as I get into the habit I will use anytime I am in the workshop.Bob making sawdust in SW Louisiana
with a EX-21
I went from using nothing to the cheap masks up to the Dust Be Gone, but still would hack away every night after being in the shop all day....then I spent 9 days in the Hospital because of a lung infection the thought "might" be caused by dust. The wife said I could not go back in the shop until I bought a "great...not good" mask. I had looked around and ended up paying the money for the Trend system. I am so glad I did. I bought a second battery and charger (each battery lasts about 7-8 hours) but found one battery should be enough unless you are sending the whole day and night in the shop. I wear the mask all day long unless I am just designing. Any cutting or sanding means wear the mask. It is not a heavy mask and I found after a couple days sometimes I would forget I had the darn thing on...it blows cool cleaned air onto your face. I have no problem wearing glasses and have hair on my face as well. I do not cough at all from dust now. I wish I would have started wearing this many years ago. Every time my wife walks into my shop and I am not wearing the helmet, she says I better not be doing any wood work with out it on... I'm sure there are other devices that work, but for my money this one is the best...yea it cost about $400 but my lungs are clean so it was worth it.Hawaiilad
Larry
Reply to Shawl pinsby KarlBThat's what I was wondering Betty: If these would work (larger) for hair?
Karl...-
Today, 04:47 PM -
Reply to Shawl pinsby RJwebWho said being bald isn’t a plus, RJ...
Today, 01:18 PM -
by will8989The perfect solution when I need a wider top on my Hegner. A magnetic sheet! I decided not to get the Pegas as the only reason was for the wider top and the top feed blade. After 19 years, my Hegner is still running like new and I couldn’t justify the expense. It was a “want” and not a “need”....
Today, 12:27 PM -
Reply to Shawl pinsby will8989Good idea Scott. Also, my daughter has long, curly hair. She twists it up and around and sticks a pencil in to hold it. I also stick a dowel in my hair when working and my hair gets in my way and I twist it up. The one in this picture would perfect for thick hair.
Today, 12:19 PM -
Reply to Shawl pinsby NC ScrollerVery Interesting. Axor being this is a vary old thread you might reach more people by starting a new thread for your video....
Today, 08:56 AM -
