pattern maker
  • pattern maker
    Has anyone used a program called "conneted lines pattern maker"?
    Is so is it any good ect. thanks
    I just tried it and used it once, then it refused to re open. Stick with Gimp and Inkscape.
    That's my two cents.
    Don R
    http://www.oldcrowwoodcrafts.weebly.com
    http://www.oldcrowscrollwerks.weebly.com
    Custom Made Scroll Saw Patterns
      I see it is free. I'd be afraid to download it.
        A very nice Free art program ~ as good as Photoshop (nearly) ~ is Artweaver. You can find it at Artweaver I have been using it for a while and it is quite nice.
        John
        I've Got A Lot More To Learn
        About Leaving Battlegrounds Alone
        "~~ Molly Venter
          Another good free photo editor is: PhotoFiltre - Download
          John
            coyote 3 has a good tracing program if that is what you are looking for
              Today, 08:57 AM
            • Dan A
              by Dan A
              Today, 06:33 AM
              Reply to Another Celtic cross
              Yesterday, 09:47 PM
            • Harry
              Reply to Toy jeeps
              by Harry
              Hi Jim.
              sure you...
              Yesterday, 01:18 PM
            • jim_mex
              Reply to Toy jeeps
              by jim_mex
              Yesterday, 10:15 AM
