Hello,
I am just setting up my Excalibur EX-30 and thought a light and magnifier would be useful. I did my research and purchased the setup from Rocker. I took it out of the box and the arm is so short that there is essentially no place you could permananty mount it. It is too short to put on the top of the upper arm or the side of the upper arm for that matter, it will work on the table or on the surface the saw sits on but then it is in the way for larger peices where you would utilize the full capacity of the EX-30 work surface.
Is anyone else using this light with an EX-30? If so where did you put it? The last thing I want to do is worry about relocating the light all of the time.
I find it a little funny that they make mention that the arm for the light is longer than the competition. What does the competition use? An illuminated monacle?
