My best tool!
  • My best tool!
    I use blue painters tape on my projects and glue the pattern to it. I've tried spray and not really that impressed with it so I've stayed with elmers or titebond but it was hard to get the glue even out in the middle of a pattern so I made me a tool to make the job easier. I took a popsicle stick and cut it in 4 pieces and glued it to another stick, let it dry and now I can push the glue around with no problem.
    Ah Haa a glue rake.....Perhaps a glue squeegee---Nicely done.
      And it helps to explain the Popsicle stains on your shirt, great idea!
        Recycling at its best.
        BTW, I have had OK results spraying both the tape and the pattern back with contact cement, and waiting about a minute. This makes a permanent bond. However you only get one chance to place the pattern.
        Ron
        My sawdust gallery
          I use the spray glue sprayed to the back of a pattern and then placed onto the raw wood to be cut on the Scroll saw or Band saw. Of course it does not come off easy...mineral spirits place on a shop towel and dabbed onto what is left of the pattern and the wood works for me. Might be a bit messy for some but works for me.
          Hawaiilad
          Larry
            Hmmm....looks like a "disposable razor". Now that is a thought also. Good Idea.
              Neat idea Darrell, the saying around here is, "anything that works" so if this works to make the glue spreading easier. Then your all set.
              Len
                Try selling them as kid's toy razors.
                Paw Paw Ray
                http://www.etsy.com/shop/PawPawsWorkshop
                  I'm curious as to why you're not impressed with adhesive spray? Applying glue to the back of your patterns seems to be much more of a hassle and how long does it take to dry so you can start cutting?
                    Reply to Wood identification needed
                    This site should be on every woodworkers computer. https://www.wood-database.com/ As has been said the first image is Wenge....
                    Today, 07:38 AM
                  • handibunny
                    Reply to I decided I needed a challenge
                    by handibunny
                    I couldn't resist (too long since any new toys) and ordered a blacklight flashlight from Amazon--same price as Harbor Freight. Should be here Tuesday--can't wait to see all the glue spots I've missed.
                    Today, 07:01 AM
                  • handibunny
                    by handibunny
                    If you google "Moradillo" you'll get more information than you'll ever need. It looks like it will work up beautifully.
                    Today, 06:59 AM
                  • dgman
                    by dgman
                    The first picture is Wenge, pronounced WHEN-ghay or WHEN-Gii. It is a very hard wood. It’s splintery and very hard to cut. When finished, it is almost black. I use it when I need a black wood for Intarsia. I do not know anything about the other wood.
                    Yesterday, 10:40 PM
                  • vgraf
                    by vgraf
                    I have a new neighbor who did a lot of woodworking in the past but had to give it up because of allergies. He sold his shop equipment and wood stockpile when he moved here, however he kept a few pieces of fancy wood and showed them to me. The first one (First Photo) he had no idea what it was. It is...
                    Yesterday, 09:31 PM
