Hi everyone I just got done making a pair of shade lamps I will try to put them on for you all to see.
piano
Just a tip...
Here is the preferred way to post photos. This method will apply a thumbnail so that messages load faster, keeping those who are still on dial up in mind.
If it is a new thread scroll down below the message box to additional options and look for manage attachments,Click on Manage Attachments, click Browse, find your file name on your computer, click it, then click Upload. It may take a few seconds to load.
Once you see the file name under current attachments you can close the window.
If you want you can Preview Post (a wise choice) then if all is well, click on Submit reply.
If you are uploading a picture to an existing thread (conversation)
Click on the Go Advanced button under the reply box, Click on Manage Attachments, click Browse, find your file name on your computer, click it, then click Upload. It may take a few seconds to load.
Good luck
Looking forward to seeing the pics."Still Montana Mike"
Thanks for the info on uploading my photos.
You are welcome...Last edited by wood-n-things; 02-05-2012, 01:55 PM.
This gallery has 2 photos.-
Today, 12:13 PM -
Reply to First Project - Stretching Catby Sandy OaksVery well done, especially for your first. I too like the added detail.
Today, 11:22 AM -
by RolfThe end result is beautiful I really like that Hummingbird design....
Today, 09:54 AM -
Reply to Help with spray adhesiveby RolfI have used all sorts of methods for putting on patterns. The only time I put a pattern directly on the wood is on Intarsia as the shaping process removes it. I only use blue tape under the pattern on very small projects.
I Use clear removable contact paper (shelf liner) on the wood and...-
Channel: Beginners Scroll Saw
Today, 09:51 AM -
Reply to Sanding and calibration disk.by RolfI agree about how it was advertised, but it is my own fault, I know better. Just for curiosity I may strip the paint off and see how true the plate is.
The good thing is that while I had my saw blade off I cleaned it sprayed Crud cutter on it let it sit then wiped it off with a skotchbright...-
Today, 09:42 AM -
