I have a dilema & can't decide what I should do with this new project. It's a 3/4 in. thick bass wood piece with the bark on either side & the pattern I made myself. Should I cut it or wood burn it? It is a little thick for cutting, but, not a problem. I'm just going to run it buy all of you to see how you feel about it. I'll let you know what I decide & the finished project will be posted for you to view. Thanks for any ideas or give me a push. HA
Project Question?
If it were me I would burn it. This is a great pattern and it would look amazing with different shades of burning.Rolf
If you are experienced in pyrography I'd burn it as well. It will look awesome."Still Montana Mike"
Thanks everyone & Mick, I have done both on some pieces too. I have been leaning toward that or just burning, because it is basswood, no wood grain. They use it a lot for carving . As a matter of fact, that's where I got the piece of wood. At our Wood Carvers annual show. They do some awsome carving & burning too, with their carvings. Will be a while before I get a start on this, as I'm finishing up the Iwo Jima cuttings that I did. Just finishing the frames. Thanks for your comments everyone.PERK
Today, 10:23 AM -
Today, 10:19 AM -
Today, 07:55 AM -
Yesterday, 08:15 PM -
Yesterday, 05:07 PM -
