any recommendations on which type and where to buy? TY
'fire extingisher'
As an old firefighter, I can tell you you need a tri-class or ABC class extinguisher. Depending on the amount of flammable liquids (varnishes, etc) you keep around a 5 lb or 10 lb is sufficient.
"A" is common combustibles (paper, wood)
"B" is flammable liquids
"C" is energized electrical equipment
Mount it in an handy spot--away from the area where you store the flammable stuff. No use if you have to reach through the flames to grab it!
And remember PASS
Pull the pin
Aim the nozzle
Sweep side to side at the base of the flames
And call 911. Firemen would much rather show up where the flames WERE as opposed to where the flames ARE.Jim
Any of the big box stores carry themRolf
All of the big box stores carry them even smaller hardware stores carry abc extinguishers.. I keep 2 in my shop, one by each door on opposite sides of my shop so i can always access at least one of them. I also have a fully stocked first aid kit in my shop."Still Montana Mike"
One thing I was always told by the pros was that I should turn the extinguisher over and shake it every month or two. Seems some of the chemicals settle and that makes it less effective when you use it.
Jim, feel free to correct me if you don't agree with this.
JohnJohn
Excalibur EX21
RBI Hawk G4
Originally posted by Crabbyboater View PostOne thing I was always told by the pros was that I should turn the extinguisher over and shake it every month or two. Seems some of the chemicals settle and that makes it less effective when you use it.
John
If you are in a very quiet place, you can put the bottle up to your ear as you invert it and hear the powder sliding down. It's the best way externally to tell if the powder is moving. On a small extinguisher, you may not feel the mass shift--unless it was really packed tight.
Just hold on tight. You don't want to drop one and snap the neck. Most are around 150psi and that 1/2 inch neck makes for a pretty fast jet. (Really messy too when that powder goes everywhere!)Jim
I have three in my shop and they are all foam. Maybe cost a little more but when the fire is out it is out, sometime with the chemical they can restart from the fumes. And the foam will protect me is I have to go through the flames.Chuck D
Jean De La Bruyere...
l
I want to add, once bought don't just ignore it. Every so often, emphasis on OFTEN check if the needle on the gauge is in the green full mark.
I had a disposable one go empty on me without use, and on my refillable one, it was getting almost to the red zone (empty) without use, I had it professionally refilled, about a month later, the needle was headed to the red zone again, without use. I brought it back to the refill place and they repaired, and refilled it. Looks fine now after a year, but I often check that needle on all my extinguishers.Last edited by Wood Dog; 01-09-2012, 10:33 AM.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
i have several kiddie extinguishers around my house but i need to have them serviced as the needles are going down for whatever reason since they were never used? WD, what place did you take yours to have them serviced?
i have one of the large 4 gallon refillable water extinguishers, i fill it 2/3 full of water and then fill the rest with air. works good for wood and paper fires, and as a monster squirt gun!Last edited by Northerner; 01-27-2012, 07:26 PM.
Northener I went to a fire and safety company in the area. Google one where you live, or call the fire department and they should be able to tell you where you can get yours refilled. It cost me $20 bucks, well worth it. Don't wait.......get it done.
Some fire extinguishers are disposable and not able to be refilled, and will have to be replaced.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
my parents had one in our family body shop and one night a friend and i were cruising around and were taking a pass through downtown and my friend started getting wet and we looked up and from a second story apartment some college kids were out with a squirt gun spraying people as we drove by so we headed to the shop grabbed our 'squirt gun' and went back downtown and they were still hanging out there window when my friend opened up on them!
it was comical, they were all soaked in a matter of seconds and everyone was laughing... good times.
Reply to Bible standby Jim McDonaldA quick Google search for fretwork book stands showed pattern on Pinterest. Might be worth a look.
Today, 12:39 PM -
Reply to Spring Issueby Quartz43I agree that with fret work the grey areas may be useful but not needed for Intarsia and some others. It would not be difficult to use grey for some patterns and just lines on others.
Another thing to note is that not many have the ability, software or equipment to stitch patterns back...-
Channel: Publisher Feedback
Today, 11:02 AM -
Reply to YoraHome Laser w/CNC Engraver/Routerby RolfThis is only my opinion.
Hi Linda, My first reaction is it looks good, and my new toy craving started to twitch, but I thing it will be very limiting very quickly.
It is a small engraving machine and if that is what you want and need maybe OK. You are limited to 1/8 shank...-
Today, 10:25 AM -
Reply to Peanuts #1by millwabI still have some puzzle blades from Ben Fink. Once I run out of them I’ll have to ask Denny what he recommends for a substitute....
Channel: Scroll Saw Puzzles
Today, 09:56 AM -
Reply to Spring Issueby Rolf[QUOTE=Quartz43;n873079]No doubt, the large patterns are a real challenge. Not many have a large size printer. Going out and finding a place to do large scans and prints is problematic with the virus and many of us are older.
I wish they would not print the patterns with the grey. Pure...-
Today, 09:47 AM -
