I inherited my dad's dremel scroll saw and am using it. It vibrates a lot--I think--I don't have much experience to compare it to. I have arthritis in my hands and find it pretty tough to work this way. I have about $200 I can spend if I want to upgrade a little bit. I am wondering if anyone knows if I can improve on it for that price. I looked at a product comparison guide I found someplace in the forum here... it mentioned several brands but did not have Dremel in the mix at all. I don't want to spend the $ and find I haven't gotten a better saw. If you have some idea, please let me know. thanks!
Dremel Scroll Saw Upgrade ??
Another option is to check out your local pawn shops, consignment stores. If no luck, just keep saving your $.
In the mean time try clamping down your saw somehow. Good luck. Come by often, new members are great assets to this forum.........and we certainly do love to see project photos. Not mandatory to post them, but sure appreciated.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
I made the leap a couple months ago from dremel to Ex 16. I was really affraid of spending that much and not seeing much difference. Saved and procrastinated for a good while and am thrilled with the upgrade. I agree, keep saving and keep eye on Craigs list paw shops, etc in your area. If you do buy used, take a blade and some wood with you.
RegisAn old beginner leaping in.
Pleased with my new EX-16.
I used to use a Dremel saw for several years. It was a great started saw and I learned a lot cutting on it. However the best thing I did was save up money for a Dewalt saw. I would agree to save up more money and/or find a deal somewhere on a Dewalt.
thank you all.Hubby bolted it down for me, its a little better. Now I can free up a wee bit of cash to address another issue. I will certainly post some pix in future and come back.
I sell my wood pieces already and its funny cuz--as for wood working--I am super novice-y. But I use it as a 'base' really for my art. I make toys & cake toppers, keepsakes so far.. will do more in future: There's links on my blog to my etsy shops... blog is: pokeberrypatch.blogspot.com
I have and am still using my Dremel scroll saw. the only problem I have had and it makes the saw vibrate is that the two pins on the bar at the rear arm wear out. This causes a loose fit and will eventually break. The parts are all internal and can be services if you want.
The first sign of this (aside from a slight vibration that will get worse as the parts wear out) is that the blades will become to long for the clamps and you will have to cut them shorter.
The parts are still sold by Dremel and cost about $4 the shipping cost like $6 so I bought two sets. Two small pins and a flat bar (approx. $4 for all three parts). With a screw driver and a bench vise I replaced them myself. They lasted me about two years and I have done it twice.....
If you call them the folks know about the problem and are willing to discuss symptoms with you if it might be somthing else.... $4 or $500....
Just my thoughts on the saw..
Happy scrolling
Like the other's have mentioned.
Look on Craigs List.. search through the different area's that your willing to travel to.
I picked up a Dewalt for $150.00 In brand new condition.
their out there, you just need to look for them.
http://www.scrollsawer.com/forum/beg...-saw/42113.htm
Good Luck.Last edited by TH'er; 12-31-2011, 12:28 PM.
One thing you might consider before you buy a new saw. The one you have has a feature that no other saw I have seen has is the ability to take the top and bottm blade holders and take them out with an allen wrench and turned them 90 degrees to the saw. This changes the 18" throat depth to infinity as it takes the back of the saw and puts it on the side.
Just take out the set screw out pull out the holder (its one piece) and turn it and put it back in then tighten the screw. Do the same with the other bottom one and insert the blade. You will have to turn yourself 90 degrees to the saw and feed your work into the blade side ways but you dont have to worry about hitting the back of the saw.
I like the saw, Yes I have had to make a repair two times in about 7 years but it only cost about 20 $ and about 3 hours total for both fixes.
Hint: Check the reviews on the saws posted in this forum before you buy.
Reply to How’s that warm weather RJ?by jim_mexHi folks - I really feel sorry for you people north of the border.
Here in Central Mexico, apart from a couple of days at the end of January where we had a couple of showers in the evenings we have seen hardly any clouds in the sky during the day since the New Year and although we 've...-
Today, 12:02 PM -
Reply to Blue Heronby jim_mexWow! - this a stunning piece!
In particular the head is so lifelike it feels like if you got too close to this bird he (or she) would reach out and nip you with its beak....-
Today, 11:52 AM -
Reply to Blue Heronby planeurHello Jo,
It is me again , and after a close look of you Heron, WOW so much details and fine cuts. Was it a gift ?
Just found the cie which sell the pattern ( in canada )
Have a good day.
planeur-
Today, 11:15 AM -
by jim_mexHi all -
Around the beginning of year I mentioned in a post that I was looking at ways to extend my existing workshop space to give me room to accommodate a midi lathe I had bought and to also allow me to undertake smallish carpentry projects in addition to scrollsaw work. Well, I finally...-
Today, 11:12 AM -
Reply to How’s that warm weather RJ?by NC ScrollerAnyone hear from Jim Finn? He is from Texas.
Today, 10:33 AM -
