How to you get a printer to print red lines instead of black?
Colored Pattern Lines.
It's all fun
Terry
Craftsman 18"
Delta 46-460 lathe
________________________
https://www.facebook.com/SillyLillyBowsAndMoreTags: None
What about a pattern I didn't make?
It's all fun
Terry
Craftsman 18"
Delta 46-460 lathe
You could try Rapid Resizer. You can print out the final pattern in any color you like, but I do use red. Great program, use it a lot.Chuck D
Jean De La Bruyere...
l
Originally posted by Terry Murphy View PostWhat about a pattern I didn't make?
If I want to change colour I use GIMP (free program)
Open the PDF and find the page I want and import.
Use select tool to select area I want. Ie big square on tools page
Select colors and then colorize. Play with the saturation and hue to get the color you want and then print.
I hope you can see the results here.
gimp.jpgDon McFarland ​Member - Durham Woodworking Club http://www.durhamwoodworkingclub.com/
Another option Terry is to scan the pattern to your computer. Put it someplace where you can find it again.
Here's what I do when I want to print a color to some patterns.
Open file in Irfanview, click File, click Print, select the printer I want to use, click printer setup, click properties, click effects, click box monochrome effect, select color by moving slide, click OK, click OK again, click Print.
I realize you may not have the same setup as I do, but if you play around with your parameters you should be able to find you can print your patterns in the color you want. Good luck.
.....and as I mentioned in my earlier post, a highlighter can be helpful if you don't want to use the printer.Last edited by Wood Dog; 12-19-2011, 05:27 PM.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Hay Chuck if I can step in on this thread. I have the rapid resizer program also. How do you just get the line to change color an not the whole pattern?
I have had a lot of trouble with the program but they have been very good at showing me how to get around the trouble an make the program work. Thanks
Originally posted by Trackman View PostHay Chuck if I can step in on this thread. I have the rapid resizer program also. How do you just get the line to change color an not the whole pattern? Thanks
Update: I checked and the last page gives you the options of several colors.Last edited by ChuckD; 12-19-2011, 08:48 PM.Chuck D
l
I did it!
I just changed the color to magenta in the preferences, and it worked.
Sometimes I just can't see the forest through the trees!
It's all fun
Terry
Craftsman 18"
Delta 46-460 lathe
Reply to More Miniature Birdhouse Ornamentsby NC ScrollerI love cutting those. Nice job.Today, 01:24 PM
by Sandy OaksFour Miniature Birdhouse Ornaments finished and ready to display. The birdhouses are Ash and the little birds are Purple Heart. I used Pegas #7 Skip blades on the birdhouses and #5 Skip blades on the little birds. The finish is dipping in Shellac further diluted with 50% denatured alcohol. Comments...You do not have permission to view this gallery.
This gallery has 4 photos.Today, 12:05 PM -
Reply to What do you think?by Gary beasleyI tried a house vac once for a dust collector. It was prone to clogging the lines and when I tried to put a cyclone can on it the vacuum collapsed the garbage can.
Yesterday, 09:29 PM -
Reply to Vasesby Gary beasleyI found this pattern in Steves catalog and freehanded a vase form. This one may appeal to the folks that bought the butterfly vase.
...Yesterday, 09:25 PM
