lower clamp problem
  • lower clamp problem
    i have an EX-21 saw and have been having a problem with the lower clamp
    which is when i go to clamp in a blade it gets pushed out when im tightening
    the knob.
    the little spinner end works fine on the knob and i clean/sand the blade ends
    and have done the same to the spinner parts but when i tighten the knob it
    just slowly pushes the blade out.
    its frustrating cause i have to take a very small flat blade screwdriver and hold
    the blade in with left hand and tighten the knob with right hand. it sucks cause
    there is no quick blade changes.
    anyone else have this problem and how do i fix it?
    Sounds like the screw on the opposite side from the knob is in too far and perhaps worn. Unless something is stuck in the back of the blade groove.
    That's all I can think of.
    Regis
    An old beginner leaping in.
    Pleased with my new EX-16.
      i have the little screw a little out past even and the knob is new but i did clean
      the rotator end with sandpaper.
        I own an EX-30 and was having the same issue. I called Ray at Seyco and he said that I had over-tightened the lower blade retainer and sprung the clamp. If you purchased the saw through Seyco they will send you a replacement retainer.
          when you say lower blade retainer do you mean the lower blade clamp?
          and when you say sprung, do you mean the sides of the clamp that has
          the set screw on one side and the knob on the other got spread apart?
          like a U getting pushed out to a V shape, but not as drastic?
            It could be that the end of the knob thread that pushes onto the blade has worn and is no longer flat.. this would then force the blade out of position when it was tightened.
            As a test swap the knobs and see if it happens on the top.
              i have taken the knob out and run it across a flat sheet of fine sandpaper so i would think the spinner end is flat.
                If you talk to Rey at Seyco, he will recommend that you do NOT rub the set screw and thumb screw ends with sandpaper. Those ends have to be perfectly flat and even. You will more than likely mess that up rubbing them with sandpaper. If those ends have even the slightest angle it will effect how it holds your blade. I know cause I made that mistake. Once I rubbed it with sandpaper, I could not seem to get the ends perfectly level and flat all around. You're better off buying the rebuilt kit that he sells. It replaces the set screw and the little end that comes out of your thumb screw.
                  But did you swap it with the top one ?
                  What happens when you do will prove whats wrong.
                    i put in a new lower knob i had and it kept pushing the blade out
                    i took a flat edge and put it against the little spinner on the old one
                    and new one and neither one were flat, so whats up with that?
                      Try what DaveP suggested, swap that thumbscrew with the one in the upper blade holder and see if it makes any difference.
                        it never hurts to try so i will give it a go and see what happens!
                          i forgot about this thread i had.
                          i ended up pulling off the lower blade chuck to take a look at it and i can see why the blades kept getting pushed out, previous owner(s) had to be cranking down really hard on the knob as the walls of the block were pushed apart so far that only the very ends of the flat parts of the knob and the set screw would touch on the blade and when it got tightened it would just push the blade out and now with the new lower clamp installed it works great!
                          i ordered the parts from Ray on a Monday and he had them in my hand on Thursday so once again great service from Seyco.
                            just wanted to report back again, its been a month since i got the new lower block installed and i have been very happy how good my excalibur has been working. bottom clamp holds the blade nice and tight the way it is supposed to with no extra over tightening of the bottom knob.
                            if anyone ever has trouble with the bottom blade being pushed out you will know what to do to fix it!
                            • Quartz43
                              Reply to My computer issues.
                              by Quartz43
                              Glad things worked out.
                              I just updated my older PC. The hard drive was 500 gb and eight years old. I cloned it to a one TB SSD (solid state drive). Put the cloned drive in and worked perfectly with all my old programs. The computer is now much faster. The new drive was about $100 and...
                              Today, 05:02 PM
                            • NC Scroller
                              Reply to Need suggestions or a bit of guidance
                              by NC Scroller
                              You nailed it.👍
                              Today, 04:03 PM
                            • NC Scroller
                              Reply to A new toy.
                              by NC Scroller
                              Once upon a time ( in the 70's) i attempted bow hunting. I believe the bow had a 45 pound draw. I quickly learned that it was not for me. It takes lot of hard work and practice just to be fair at it. Good is a whole different level. I hope you do better than I did.
                              Today, 04:02 PM
                            • Linda In Phoenix
                              Reply to A new toy.
                              by Linda In Phoenix
                              Now that's a cool way to maintain hand/eye coordination. Enjoy that toy--- and--- HAPPY FATHERS DAY TO ALL THE DADS OUT THERE!
                              Today, 01:30 PM
                            • Linda In Phoenix
                              by Linda In Phoenix
                              So glad you are back up and running. You will be awed by the speed of your new drive, fresh drivers, and cleaned up files. Spring housecleaning!
                              Today, 01:28 PM
