I used poplar for this and planed it down as thin as my planer would go ...any suggestions on how to make it better?
First bookmark
You will find that using hardwoods is frustrating as the thinner they get the more fragile/brittle they become. We (not all of us but the majority of us) typically make book marks Out of 1/16" plywood or even 1/32" ply and I order mine online. You can stack about 8-10 at a time and they are remarkably strong.
Yours turned out very nice how thick did it end up being?"Still Montana Mike"
Try sloans that is where I got the really thin stuff. Plywoods"Still Montana Mike"
Dang they are all sold out of 1/16 and 1/32...and thank you for the compliment!
E-mail them and ask when they expect a new supply. They may just need to update their site.Last edited by wood-n-things; 11-04-2011, 11:25 AM.
Try wildwood designs and I'll look through my receipts and see if I have gotten it elsewhere. I know I have just can't remember where I have several sheets in stock.
Start a new thread under wood & materials and use the title Where to buy thin plywood? 1/32" You will get more responses in short order...in your message inside the thread mention you are making book marks and that you have tried sloans already but they are out of stock."Still Montana Mike"
I grind stuff down with my belt and disk sander then use the hand held orbital and just grind em down. I get them to around 1/16". I have been using mesquite and grapefruit wood from the trees in my yard.
I have used lots of stuff for book marks but find that my wood ones are much more satisfying.Pacifism is great, as long as everyone is participating.
StephenD
Desert Woodcrafters
Stephen that is great but sure is a waste of wood (makes me cringe to sand down that much) LOL. But since it is out of your yard makes it a little more palatable."Still Montana Mike"
A couple of things:
Definitely stack cut these as it makes it easier to cut.
You could get a bit thinner by using a piece of 3/4" plywood in your planer above your table. This should have a stop block on the bottom side to keep it from moving. You should also sand this with about 220 grit sandpaper.
Be careful with thin stock as planers can eat them up. (Ask me how I know! )
I've also used two pieces of wood veneer stuck together with double stick tape. (Thin stuff, not what you get at Home Depot or Wal Mart.) I haven't tried yellow glue yet, but I'm going to.
KarlKarl in Sunny Southwest Florida
Reply to Bruce’s new toysby RolfThe Jet looks like a clone of the Tormak system. The Pasch is also a good air brush brand. Nice deals!
Our annual club show always has a "tool coral" Our big show is coming up in a few weeks. Sept 17-18-
Today, 08:25 AM -
Reply to lion looking to the skyby RolfI agree with Linda on your frame choice....
Today, 08:18 AM -
Reply to Greetings again...by RolfWelcome back! Check to see if you have a club or other scroll saw enthusiasts near you. You have one of the best Intarsia artists about 3 hours away from you. I know she does classes. Janette Square. she may also know of other scrollers in your area. http://www.square-designs.com/
In the mean...-
Channel: Welcome Members
Today, 08:15 AM -
Reply to Greetings again...by meflickHi Brad and welcome back. Good to hear you have been able to upgrade your work area. A comfortable work area does make scrolling more enjoyable. Look forward to seeing some of your recent work.
Today, 07:00 AM -
