I just recently made my first pendulum clock. It's not big....just about 13 inches high by 9 inches wide. For all you clock making people out there, whats the best type of hook to put on these clocks (saw tooth, triangle, etc)? From what I read, the clock has to be level and straight at all times for the pendulum to work. I don't want to use an improper hook and have problems with the movement. Thanks.
Hanging a pendulum clock
Something I like to do with larger items that need to hang level is to use 2 hangers. Either the sawtooth or the triangle ones work. I generally use the sawtooth ones where I don't want the mounting to show. It takes a little fussing to get the nails/screws spotted precisely on the wall for mounting, but since they are hidden by the piece, you can always tweak them a little and cover up any extra holes in the wall.
Problem with the triangle ones, at least the ones I use, is that if they are below the top of the piece, they are hard to get hooked on the wall, sometimes. If the triangles are above the top of the piece, it's easier to get them hooked and it's easier to mark the wall where it needs to hang level. Unfortunately they will show and that isn't always desireable.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
.I'v been doing pendulum clocks on and off for quite a few years..(all battry powered ). regaurdless of the power hand, weight or battery the biggest thing is to have them mounted so the pendulum has clearance on ALL sides and front to back...i generaly use the saw tooth type hanger...usually only one (depending on the weight of the clock.......i always put spacer at the bottom to keep everything parallel to the wall (no tilt front to rear...) the saw tooth allows adjustment side to side with out a bunch of extra work.....two hangers would have to be exactly even in height ...extra un-needed work in my opinion.
Tim, depends on the weight of the clock. 9 X 13 most likely is not very heavy, I would just use a sawtooth hanger. I have made a few larger ones with mechanical works, I just drilled a hole in the back board for hanging.Mick, - Delta P-20
Thank you all for your responses. I guess what I was getting at was what Dave brought up. My concern was when you hang something, it generally hangs at a little bit of an angle due to the hook sticking out of the wall. I'll see how a saw tooth hanger goes and then if need be, put a spacer on the bottom so it hangs perfectly parallel to the wall as Dave mentioned. Thanks again.
What kind of movement are you using? By the size of the clock, I'm going to assume it's a quartz (battery) movement. The pendulum on those is purely ornamental, and the only thing necessary (as Dave said) is proper clearance around it. If it's a mechanical movement, then the pendulum is an integral part of keeping the clock running. One thing I've found over the years building clocks is that if you're measuring plumb and level by the clock case you may have to allow for the movement not being mounted exactly plumb and level IN the case. Set it up so that the case is level and then watch and listen. You may have to tweek it a bit to allow for how the movement is mounted in the case.
As far as the method of mounting, you don't need to over-engineer it on a clock that size. Depending on the design of the clock, you could use a sawtooth hanger or even a hole in the back of the case. Unless you live in an earthquake zone or have teenagers bouncing off the walls, the clock is going to stay level once you get it mounted. One thing I did with a cukoo clock I had that was a little difficult to get mounted was once it stayed running I put a small pencil mark at one corner as a reference in case I ever had to take it down. Then I knew exactly where to put it back up.
Hope this helps.Bruce
visit sometime
Hawk 220VS, Delta 40-570
Thanks again everyone. I decided to use a sawtooth hanger. After hanging it up, even with it not being completely parallel to the wall, the pendulum works fine. I might put a spacer on the bottom as suggested just to make it look better but everything is working good.
Reply to Question about tilting head sawsby cwmageeThe last time I visited with Denny Winter 2020, I had an opportunity to try out the PEGA Saw that Denny has set up in his store. I was extremely impressed with the saw performance. It will be the saw that replaces my EX21 when I need a replacement. When I visite Denny I was considering purchasing it...
Yesterday, 10:24 PM -
Reply to Harbor Fraughtby Jim McDonaldWhen I worked retail, we would have products plainly labeled "One rebate per address". And people would go ballistic six weeks later when their claims for three or four got shot down.
Can't imagine if it had been in small print like the ads of today.-
Yesterday, 09:46 PM -
by mccrookstonFirst time posting.
I have a Pegas Scroll Saw that is almost 2 years old.
I saw about 1-2 hours a night right now and the speed will slow down and speed up on its own.
Sometimes it will run full speed for a week and then switch to slow for a week.
Any ideas on what might be causing...-
Yesterday, 06:01 PM -
Reply to Harbor Fraughtby will8989That is the one store I physically get sick as soon as I walk in. The odor of rubber is overwhelming and I’m good for 3 minutes before I have to leave. Sure glad other stores aren’t like that. Hmmm maybe my bank balance would be higher if they were.
Yesterday, 03:24 PM -
Reply to Harbor Fraughtby Bill WilsonI wonder if their effort to offer better quality products may have something to do with it. Seems like they want to market themselves as something more than just a cheap tool supplier. Maybe reducing the number of things eligible for the big discount coupons is part of a campaign to change their image....
Yesterday, 02:41 PM -
