A chip in BB
  • A chip in BB
    What do you more experienced sawyers do when a tiny chip pops off the top layer of BB plywood? This has happened to me a couple times after cutting and a little sanding I see where a small chip, maybe 1/8" diameter, disappears next to a cut. I'm referring to just the top layer of the plys.
    Thanks in advance for your advice.
    Mike
    I mix sawdust with a little slow zap super glue then spray it with accelorater wait about 30 sec then sand or file it to shape Mike but don't wait to long to sand or file it this stuff dries tough as nails
      Daryl, how the heck do you file or sand something as small as 1/8" in diameter?
      Mike
        very carefully, lol
        lost some skin a few times, and there's nothing that compares to a sandpaper burn.
        Jeff Powell
          Mike, what type of blade are you using when you get a chip? Could also be the plywood, I usually use the Finnish birch plywood. Have never had a problem with chipping on the top, can't say the same for the bottom though. When sanding a cut make sure you sand from the top of the plywood down. I use tiny files and always make sure to file downwards.
          Mick P-20
          Mick, - Delta P-20
            Mike I have a very fine set of jewlers files and I go very slow, unfortunately I broke a piece off of the pattern I am cutting today and its almost dead center so its gona be hard to hide
              I bought a $20 or so set of multi-colored magic markers at a craft store and use them to match colors of occasional chips that come off my puzzles. Often it's quite difficult to tell unless you look very closely.
              Carter
              • evilbadger
                Reply to Marc Tovar's MLT-13
                by evilbadger
                I don't remember which one I used but I think it was somewhere around #12 which is .029 diameter. Anything between 12 and 19 will work you would just adjust your slot width. There is a pattern for bending it to shape do you have that?
                Today, 05:12 AM
              • hotshot
                Reply to Old wooden plates.
                by hotshot
                Very Nice cuttings. I think my favorite is the train.
                Yesterday, 09:22 PM
              • Eugene Downes
                Old wooden plates.
                by Eugene Downes
                Over the years I've found that cutting old wooden plates can be very rewarding. Most of them are very good wood and when you finish your cut out the plate already has a nice finish on it.. I normally buy mine at yard sales or Good Will whenever I can find them....
                Yesterday, 06:45 PM
              • Eugene Downes
                Reply to Squaring scroll saw
                by Eugene Downes
                I've found in the past that you can find some very nice wood from old wooden plates. When you finish your cut out the wood already has a nice finish. I am only adding a picture of 6 but I have done many of these....
                Yesterday, 05:53 PM
              • RJweb
                Reply to Happy day
                by RJweb
                Betty, glad to see that you are having a good day, best of health to you SIL, RJ
                Yesterday, 10:46 AM
