made a bench
  • made a bench
    Wow what a difference this makes, no more vibration, mounting the saw to my work bench did not work. I remembered there was a post about a scroll saw bench and than I found this free plan, I altered the height to accommodate me sitting down, also my shop floor is covered with mats so I didn't have to put mats under the feet. Don
    I can't tell from these but did you raise the back of the saw 2-3 inches? Nice looking bench really sturdy looking...
      Hey Don, Years ago when I had a Dremel Saw I built that stand. It was easy to build and worked great. I Don't have the saw anymore, but I still use the stand. I have my 1" belt sander mounted to it.
      Dan in So.Ca.
        Great job on the bench. One thing I don't understand, how on earth do you keep your shop so clean. I can clean mine everyday and I couldn't come up with something that looked like that. Everything looks good. David
        My grandbabies are what keep me going
          Nicely done. Looks solid as a rock.
            not raised
            No It's level, Don
              That is a great bench! You did very well!!!
              John
              I've Got A Lot More To Learn
              About Leaving Battlegrounds Alone
              "~~ Molly Venter
                Sweeeeet stand Don, but get yourself a pillow for the stool, or you will soon have flat cheeks.....
                  Nice looking bench.
                  Delta P-20 & Q-3
                    Looks nice Don!
                    -- Rick --
                      Your stand does look nice as I said. You do what is most comfortable for you but may I suggest placing a 2x4 under the rear of the stand temporarily. You may find as a lot of us have that it will tilt the table just enough that you can see to the lines to cut easier and it will remove some of the strain on your shoulder and neck muscles allowing you to cut longer and with less fatigue and less tightening of the neck and shoulder muscles. It is just temporary so what do you have to lose...You may find you enjoy scrolling even more than before. If you find you like it attaching the 2x4 permanently will be an easy fix for you.
                      Let me know if you give it a go. I'll be curious what you think of my suggestion.
                        scroll saw bench
                        I had to wait awhile to try your suggestion, had to under go a little Sugary. Tried it on Monday, it made a big difference in my line of sight. Thanks, Don
                          I'm so glad you gave it a try and it worked well for you. I hope the surgery went well and was nothing too serious. Here are best wishes for a full and rapid recovery.
                            Great looking bench! Where did you get the free plan, if I may ask? I might make me one of those.
                            SQ
                            If you can't fix it with sawdust and glue, it's not worth fixing.
                              scroll saw bench plan
                              SQ
                              Came from FREE Scrollsaw Stand Woodworking Plan
                              • Linda In Phoenix
                                by Linda In Phoenix
                                Yesterday, 09:55 PM
                              • Linda In Phoenix
                                Reply to Wedding Rings
                                by Linda In Phoenix
                                Yesterday, 09:51 PM
                              • Linda In Phoenix
                                by Linda In Phoenix
                                Yesterday, 09:50 PM
                              • Sandy Oaks
                                Wedding Rings
                                by Sandy Oaks
                                This gallery has 1 photos.
                                Yesterday, 01:13 PM
                              • hotshot
                                by hotshot
                                I...
                                Yesterday, 11:39 AM
