When I received this pattern from Steve Good I knew I had to cut it next.
The pattern called for using 3 1/4" pieces for the stock but after cutting the center one I thought it would be too thick. I used 1/8" for the outside pieces and it came out ok.
The light colored plate where the bullets are put in was to be 1/8" but I cut them from the 1/8" and used the belt sander to grind off two layers of the three ply.
Steve makes some really great patterns and this is going to be my fav for a while.
I painted on black stamp pad ink for the metal parts, the stock is black walnut stain and the plate is from the watco exterior oil that I soaked it in.
I stack cut these so there will be more coming soon.
