We are doing hand work on corian. Any challenging job we can done.
Hand work on corian
Corian is an interesting media to work with. It's a resin material so it last forever. The only problem for we scrollers is that the blade heats and melts the corian as you try to cut it with a scroll saw. I stumbled across a solution a few years ago. If you apply the clear packing tape used to seal boxes over the areas you want to cut, the blade gets coated by the plastic tape and its' glue and this protects it form heating up so you can use the Corian as your media.
Check out my Welcome sign in my NHokpic gallery on this site. I've also made several crosses with Corian.
A few other interesting notes about Corian. You can use a router to put a profile on the edges of any piece. Unlike the scroll saw, a router doesn't heat like a scroll saw blade. One last note, if you want to polish a piece of Corian, you can do this by using a very fine sandpaper.Attached FilesIt's never hot or cold in NH, it's always seasonal!
NHokpic
The problem with the heating of the blade seems to come from the side to side motion of some saws. I have a Boice Crane and my brother has a Hegner. Neither of these have a problem with Corian. The packing tape may also keep the blade in the center of the cut.
You can also "scroll" with a router. If it is in a table you can use a 1/8" upspiral bit (or smaller) to quickly open large areas. You don't need to pre-drill for inside cuts this way.
Avoid sharp inside corners as they are stress risers, a place for cracks to start.
I did the dog ornaments with a router. My brother hand carved the Rose. A customer did the candy dishes." and now for something completely different..."
http://sites.google.com/site/coriartinc
I use a Hegner saw and have not had any problems with burning when cutting corian. I have made several scrolled bowls and baskets with it.Attached FilesHawaiilad
Larry
Larry - I'm curious... 1st question, "Hegner" is a name I'm not familiar with. I assume it's a saw name and probably very good. 2nd question... did you use a low speed?
I'm more of a wood worker then a scroller, but I have learned the basics of srolling and love to incorporate it into my works. This means that I bought a popular saw (the Dewalt 20 inch [580? I think]). I have a few of my works included in my gallery which shows I'm on a learning curve. I'll be looking at your work if you have a gallery LarryIt's never hot or cold in NH, it's always seasonal!
I cut this trivet - my own design and my all time favorite pig cutting board design by Dave Van Ess from corian and had no problems with melting. It cuts very easy, but makes a very dusty mess. The scroll saw is a DeWalt 788. I think I used a #5 blade.
SQLast edited by susieq4131; 09-24-2011, 12:52 AM.If you can't fix it with sawdust and glue, it's not worth fixing.
Very interesting Susieq4131 because I have the same saw. I can't cut more the an inch without the blade binding, but adding the tape solves that problem. Like I stated, I'm much more of a woodworker then a scroller, but I love incorporating scrolling in my furniture. It's like the icing on the cake.
So I'm curious... what speed are you all using while cutting Corian. I mostly use a top speed and I have problems cutting Corian without tape.It's never hot or cold in NH, it's always seasonal!
Originally posted by NHokpic View PostVery interesting Susieq4131 because I have the same saw. I can't cut more the an inch without the blade binding, but adding the tape solves that problem. Like I stated, I'm much more of a woodworker then a scroller, but I love incorporating scrolling in my furniture. It's like the icing on the cake.
SQIf you can't fix it with sawdust and glue, it's not worth fixing.
I run my scrollsaw on the fastest speed and just slow the feed rate of the corian into the blade....in fact all my cutting is done the same way. I also am cutting 1/2" corian using a #5 & #7 blades...I have used the reverse tooth blade and the polar blade and they both cut well with corian.Hawaiilad
Larry
Reply to Space Forceby hotshotInitially, I was thinking pretty well impossible without floating the element, but check this out: https://www.etsy.com/listing/1200589649/space-force-metal-art-sign-military-sign?click_key=30b0054c7ac246f6d4a736212655d6b25a0 eeef3%3A1200589649&click_sum=bf9efb4a&ref=shop_hom e_recs_1
Yesterday, 11:13 PM -
Reply to Easter Bunnyby jim_mexVery nice Alex - I really like your 3D technique and the precision of your work plus your designs are really good.
Well done!Yesterday, 09:17 AM -
Reply to Space Forceby jamielineHere is what I'm working with. I have the lettering set to match the other plaques using inkscape. Just trying to figure out how to layout the center to cut....
02-05-2023, 01:51 PM -
by will8989WAIT! WHAT?? I check fb today and see this “someone you may know.” Ok but the last name is the same as my maiden name. My grandfather had the name changed from the original Russian name by the judge,who took a few letters off. So I look further and my cousin Chris is listed on there, who I have...
02-05-2023, 11:53 AM -
Reply to Space Forceby cwmageeI just Goggled Space Force Logo and got more than dozen different sources & items to choose from.
02-05-2023, 10:19 AM -
