When you stack cut, do you use the whole 2" capacity if you had 1/2 inch stock do you cut 2, 3, or 4 at a time what about 1/8 inch stock what would be a safe number to cut at one time thanks Karl
stack cutting
Karl, I stack cut 3, 1/8" plywood or 1, 1/4" with 1, 1/8". But I usually use a 2/0, 28 t.p.i blade. Stacking too many pieces and your bottom piece won't come out very good. Try a few combinations and see what works best for you. The thicker the stack the harder your saw will have to work.Mick, - Delta P-20
G'day Karl,
There is point of diminishing return when stack cutting.
You may be able to stack four pieces of 3mm and still cut pretty quickly, but 5 pieces may slow you down and make the saw work harder, so that nothing is gained by cutting that extra piece. I find it is often quicker and easier to split the stack and cut two lots, one of three and one of two, if that makes any sense.
The above are examples only and you will have to find out where you think the diminishing return point is.Regards
John
"The Golden Mile"John Wayne
Some of my Stuff
Retired Medically Unfit Police Officers ***.
On 1/8" Baltic Birch I cut from 3 to 5 pieces in a stack. For alder, maple, cottonwood, birch and cedar I cut between 1/2" and 3/4" depending on detail and hardness of the wood. Play with it and see what works best for your application. Lots of folks cut 3/4" oak stock. Tension and blade size will have a big impact on your success.Got Moose?
I usually stack cut ornaments (4-6) and bookmarks (10-12) and sometimes scenes or animal portraits (2-3). I never go past 3/4" high stack and my maximum is usually only 3/8 to 1/2. As Mick said, with a small blade, you need to have a shorter stack. The harder the wood, the shorter the stack.
Keep the tension as high as you can and be careful not to put side pressure on the blade or you will bevel your cut and lose detail and bridges in the bottom layer.
George
delta 650, hawk G426
I am in line with George,
Most of my ornaments are cut from 1/16 birch ply, I do six at a time with a 2/0 Olson even with the fine details. For the 1/8 which I rarely use it 3 to 4 layers.Rolf
I cut a piece of 2X4 cedar into a bracelet, and it took FOREVER to cut it and I had to use a #9 blade and push really hard! For grins, I had also stack cut various sizes of wood to nearly 2-inches tall, and it, too, took forever, pushing hard. Not worth it, except that there really was no choice for the bracelet.
Reply to My lucky day!by Bill WilsonBeing younger than 65, with no qualifying health conditions, I don't anticipate getting a vaccine for some time. My wife works for the school district, so she may be eligible in the next phase. President Biden says that supply will be sufficient for all US adults by end of May. I'm hoping that proves...
Today, 04:16 PM -
Reply to What do you think?by MidMich324Will a shop vac work for the table saw?.
Today, 11:26 AM -
Reply to What do you think?by MidMich324Thank- you for the feedback. While cleaning it up here are some interesting details. It has a paper bag filter. Then a second cloth filter before two motors. There is a local Wallvac dealer in Grand Rapids for parts. They have the bags in stock. They also said based on the serial number be...
Today, 11:25 AM -
Reply to Another Mid-Michigan Scrollerby Mr ChipsReally nice work.
Channel: Welcome Members
Today, 08:39 AM -
