Wondering if I might be able to get a little guidance. My DW788 tends to rub against the table to the far back left corner. I know if I apply less pressure the blade will not drift. The tension is stong enough to a high pitched pluck. The set screw is centered, as a matter of fact I have moved it to the right in order to compensate. Any idea of what it might be since at this point it is shaving little by little at my table. Just wondering if it is something wrong with my flawless 788 or is it me. Thanks everyone who might know what is happening.
Blades a drifting
Can you adjust your table? It sounds like the table may be off center a little. I'd loosen the trunions and try to move the table slightly to get the blade in the center of the cutting hole."Still Montana Mike"
funny you should ask
Wow, as soon as you mentioned that I happened to notice that I am missing a big black headed screw. The table will not stay at center. WOW thats amazing. Thank you for sugguesting that idea. Now I just have to find an IPB for my 788 and put one or order. Thank you very much for your help.
Mick, thanks for your input as well
Scroller777
Reply to Spiral Blades - Tips & Tricks?Thanks for the post. I have tried spirals in the past and had lots of issues. I need to set down one day and keep cutting with them until I get the hang of it. Part of my problem may have been covered by your number 7. Tried pine thinking it would be easy to cut but now realize the grain may have...
Today, 07:05 PM -
Reply to Eagleby Sandy OaksI agree, a beautiful piece and wonderful cutting. Years ago, my father had Alzheimer. The last six months we had him in the VA center in St. Cloud MN. His wood work shop is still in MN. I could not take it down to TN....
Today, 12:00 PM -
Today, 09:16 AM -
Today, 05:27 AM -
