Hello!
I have finished sawing the pieces for my first bigger clock project. I just need to do some sanding first and then I'm ready for assembling the clock. I feel more than little insecure and need your good advice on assembly. The clock I'm making is Worthington wall clock in red oak.
Now, the instructions say to fix the inner support structure (made of 3/4" oak) with glue and screws. It also tells to secure the back piece(s) to the support with glue and screws. But all the rest of instructions it's just
"assemble" or mostly "attach".
What do you think or recommend? Is it just glue that's supposed to hold this thing together??? Or should I use tiny brass brads (or ever tiny screws?) with glue. Or tiny nails without heads between the pieces, like little dowels? I do not have access to Aleene's wonder glue you've mostly been recommending here, it'll be just normal PVA wood glue.
I'm especially worried about attaching the gable ornament to the edges of the roof pieces. The humidity will change quite a lot during the year and I have it hard to believe glue would hold in such a small strip. The pattern does include overlay pieces that would cover brads or screws of the gable ornament, but I would like to omit those if possible. The other similar overlays are clearly for decoration only and I simply don't like them.
What I dread the most is splitting the wood if I'd use brads. My deadline is in mid-October and I would need to mail order some new wood if something should need reworking. Hence I cannot afford any bad mistakes.
The bezel came also with tiny brads. Any hints here? Should I drill starter holes for brads?
I'm planning the finish the clock with Danish oil. A sating finish is preferred, I don't like much gloss. Do you think I can leave it without any varnish? Will it be too dull or is varnish needed for protection in the long run?
All help is highly appreciated,
-Satu
-Satu
