Art Gecko
  • Art Gecko
    Well I got it done. I still have to glue the eyes in place.
    I may use some sort of solar light to illuminate them from behind.
    I polished the aluminum with Mothers Aluminum polish and some disposable shop towels.
    The finished gecko is around 18" long and 10 inches wide.
    The legs are bent so the body will be raised off the fence that it will be mounted on.
    This is for a friends RV lot where his grandson comes to visit and is infatuated with Geckos.
    Nice job Carl.
    (And I will not ask where you got a used stop sign)
    Regards,
    Marcel
    A thought: A gecko from a used stop sign. Now, if a stop sign is missing on a corner and an accident occurs, and if the car is insured by the company that has a talking gecko in their ads: that would definitely be ironic.
    http://marleb.com
      I love that thought
      The STOP sign came from a recycling bin in the Public Works yard.
      The reflective coating on the sign had lost its shine.
      Vandalism is a pain.
      Revenge is mine sayeth the Gecko
        Pretty neat, Carl!
        It will be worth all the frustration you went through to see the look on that youngster's face when he sees it.
        Good job.
        Sandy
          Carl,
          Well that is just clever as can be !
          Good job !
          ...~Robert~
          DW788 and Hawk 226
            Flat out kewl" Carl! Nicely done and excellent perseverence!
            D. Platt
              Nice one Carl.
              Rhys H.
                Great work Carl
                Charlie
                Craftsman 18in. 21609
                  How many blades did you burn up on that one Carl??? Did you find one thet worked better than others?
                    Neal I went through around a dozen scrolling blades.
                    In the end I used 6" junior hacksawblades to rough out the shape. They are around 3/8 deep so it limits the turns you can make.
                    Almost like a bandsaw.
                    Then I used a couple of double tooth number 5's I had left over.
                    I have to deburr the edges before I hand it over.
                    I know I should have done that before polishing but I wanted to see the shine. It looks like chrome.
                    I have to figure out how to photograph it without the glare. I may need to build a light tent, which I keep putting off.
                    Thanks everyone for the comments. makes it worth while.
                      Carl... To cool To cool. how are you going to do the solor thing? and it just a thought, never tryed this, but have wondered how. some quilters netting would work on a picture of the project. i use it in giving a quilt some debt. it comes in many colors. and maybe.???? just laying or stretching it over the project, maybe that would keep the glar off. mmmmm well maybe i should tery it first, before posting it good job. your friend Evie
                        interesting idea and pretty slick. how about buying a cheap solar light and stealing all the parts out of it. The one I installed at the bottom of my deck stairs was only $10. It has a small solar collector, a little circuit board and a single AA rechargable battery. The light itself is just a single LED, but it lights up the area enough that i know where the stairs are...I bet you could work that into your gecko. It is light sensitive, so it only turns on in the dark.
                        Jeff Powell
                          oh duh... I see you already thought of the solar idea...guess I didn't read so well.
                          Jeff Powell
                            Rolf,
                            Are you ok Rolf?
                            Today, 05:43 PM
                          • Jim McDonald
                            by Jim McDonald
                            Today, 09:10 AM
                            Today, 07:43 AM
                          • evilbadger
                            by evilbadger
                            Today, 06:40 AM
                            Yesterday, 08:41 PM
