All went well until halfway thru my horses my blower quit blowing on my Dremel 1680. It's not easy scrolling and blowing at the same time. I then went out to my garage and found an old aquarium pump and taped the tubing from the pump to the blower nozzle of the saw and it worked fine. Oddly enough, the Dremel blower started working again about 15 minutes later. It quit working for me once before too and I just ignored it and it started right back up again. Strange. When cutting blades of grass you can't afford any sawdust in the way.
Two more per request - failing blower
Hi Mike,
VERY nice work.
The aquarium motor makes an ideal replacement for the original blower, and is suggested as such in many scrollsaw books.
With a long tube and a "box" on top of the motor I suppose the noise level would be acceptable
Regards,
Marcelhttp://marleb.com
Excellent work there Mike
Charlie,
Wow! NICE WORK!!!!! I hope you sold those for more that 5 bucks, unless they were whitetail bucks!!
Is the "blower" failing (its usually a simple rubber bellows type "pump" that the bottom arm "pumps" on its downstroke) or is your hose clogging?? Blow the hose out with compressed air, or take a really deep breath....Your bellows may be full of dust....."Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
D. Platt
Mike I just love the job you did on the horses may I ask what type of wood did you use, what are the diminsions and from what source did you get the pattern TIA
DarylDaryl S. Walters Psycotic scroller with a DeWalt 788
Barry, I pulled the hose off and put my hand up to the hole in the side of the saw and felt no air movement at all. Like I mentioned, it's working fine now but when I get my air compressor back from my son in law, I will try the compressed air into the saw. Thanks for the advice. And yes, I will get more than $5 each.
Daryl, thanks for the compliment. I use 1/4" BB plywood for pretty much all my portaits. The measurements are around 7" X 9". I get the majority of my patterns from either Free Scrollsaw Patterns or Absolutely Free Scrollsaw Patterns. These are 2 free sites that are MSN groups that annoyingly you have to join.
Marsha, I could only wish. Thanks much.
Also, thanks Charlie and Carl. I have learned from the best.
Mike,
Nice work sirI really like the horses !
Good job !
I had a 1680 and everything quit working! Worked one day, dead the nextGot my dw788 and now the 1680 just stubs my toe from time to time
...~Robert~
DW788 and Hawk 226
Hey Sawduster
First, I like the sir part.I don't get called that too often. Second. How long did you have your Dremel before it puked? Did you oil it periodically? The Dewalt gets more tempting all the time. Amazon.com has them for for $420 right now with free shipping. They also have $25 off right now on all power tools. Sounds like a pretty good deal, but it's still a little more than chump change.
My Dremel did the same thing to me (locked up) here is a link http://www.scrollsawer.com/forum/showthread.php?t=6649 to that thread if your interested. I feel my problem was user error, I failed to oil it. The manual says every 50 hours of use. I blew it big time!But then again I got a Dewalt now....
Bill
DeWalt 788
aut viam inveniam aut faciam
Mike,
As for the sir thing...what can i say? i had home-raisin'
I inherited the Dremel when I convinced The Shop Widow to spend the rest of her life with me. It was her late husbands and still in the box but a couple of years old . I used it for about 4 months, mostly on the weekends and yes, I did oil the bearings. It could be as simple as a switch ....never tore into it. By then I was hooked and it was easy to justify the 788. Gotta tell ya man that saw changed my life and the quality of my work ! If you can afford it without having to eat beans and peanut butter for a month, in my opinion ya can't go wrong. I bought the stand that goes with it as well and I am very happy. The ease of the blade change alone lowered my rookie frustration level by a noticeable margin. some folks also purchase a lifting arm for it but I have found that a piece of 2 x 4 on edge fits perfectly at the back. I hear there are a lot of problems lately with a less-than-flat deck so I would be careful in that regard
Just my ( rookie ) 2 cents...~Robert~
DW788 and Hawk 226
Reply to Cutting Stylesby KarlBSweet looking display. Excellent examples of the puzzles.
Karl-
Channel: Scroll Saw Puzzles
Today, 09:18 PM -
Quarter inch BB with Red Gum (Australian Eucalyptus) veneer. My first attempt at veneering and there are a couple spots where there was not quit enough glue so small pieces of the veneer came off....
Today, 07:59 PM -
by millwabIn preparation for a scrolling demonstration I decided to make up a piece that would show the different ways I've cut puzzles. It's 2 layers of 1/8" BB. The puzzles were cut out as tray puzzles and then glued back in so pieces wouldn't get lost as it was handled.
Today, 04:41 PM -
by jim_mexUpdate at 13 April – Its been almost a month since my last post and my shop extension is progressing albeit slowly largely due to me nibbling at it on a regular basis rather than sticking with it and going full blast to get it finished.
The outside of the extension is almost finished apart...-
Today, 03:45 PM -
Reply to New Toy!by RolfQuartz I only bought the air filter, That same model is sold by many distributors, I see Grizzly has it and several others. I was going to build one but this thing works great. I will get a charcoal filter for it also. Great when doing Pyrography. They also had a Pfingst brand flex shaft tool I haven't...
Today, 07:50 AM -
