I've using a FD-NS 2/0 to stack cut 1/8" BB x 2 with great results. The control is great and it doesn't cut to fast or to slow and it doesn't wer the blades out quick. I'm wanting to up production and cut 1/8" x 3 or 4 for a total of 3/8" and 1/2" cuts. What size spiral will be best for those size cuts? Should I go up and use a #1 and #3 respectively?
Spiral size for stacking?
Confuscious didn't own a scrollsaw either.Tags: None -
The 2/0 spiral should work just fine even with a 1/2" stack, it will go a little slower but that should be it. If you do go with the #1 spiral you will notice it to be a little more aggressive, there really should be no need for a #3 unless your doing say some viening and that is the size you need.
I pretty much just use 2/0 spirals for my projects and on occasion a #1. I bought half a gross of #5 spirals almost a year ago when I first started, and I have yet to use even a dozen.....Bill
DeWalt 788
aut viam inveniam aut faciam
God gives us only what we can handle.. Apparently God thinks I am one tough cookie..... -
I think I tried a 2/0 on a 3/8" piece and felt like I was pushing it size wise and that's why I backed up to stacking only 2 pieces. I might be wrong though. If I use a 2/0 on 3/8" or 1/2" should I speed it up some? I normally run my 788 on 5 or 5 1/2 speed all the time for the portraits and hardwood stuff.Confuscious says, "The cautious seldom err".
Confuscious didn't own a scrollsaw either.Comment
I too have a 788 and I cut with my saw on it's fastest setting, especially when stack cutting, but do what feels most comfortable to you, and still allow you to maintain good control.Bill
DeWalt 788
God gives us only what we can handle.. Apparently God thinks I am one tough cookie.....Comment
Reply to About ornament exchangeby Jim McDonaldDave, I will participate. Thanks for doing this again.
Yesterday, 09:10 AM -
Reply to Testing this blower motorby RolfWithout the complete schematic it is hard to know what is correct.
That said, it is a multispeed blower that obviously has a controller board. That board varies the power to the motor. By doing what you did you bypassed that. You put power across the low and high windings. If any thing connecting...-
Yesterday, 07:43 AM -
Reply to Testing this blower motorby evilbadgerIf he connected to red and black and the motor spun wouldn't that indicate the motor is grounded? Without connecting the white the circuit isn't complete and the motor should not spin.
Yesterday, 06:40 AM -
Reply to Testing this blower motorby cwmageeThe reason for the smoke is incorrect wiring, posible melted insulation between motor windings and motor frame.
You mentioned connecting power to the red & and black wire. Did you do anything with White wire? Per the lable on the motor the black wire is high the Red is low. White common...-
09-28-2023, 08:41 PM -
