Its Finally Here!
  • Its Finally Here!
    UPS finally delivered my DW788 saw today just as I am getting ready to leave for a week. Will have to wait until 8/30 to check it out. I ordered on 8/8 & arrived today 8/21. Wildwood/Cherry Tree is quicker than this. Oh well its here & when I get back home will check to make sure I have an even table, that my blade holders aren't so far apart & all the other things you would hope would be right on a new saw! Don't mean to be so negative guess I'm just disappointed I can't get it set up & use right away. Work sucks! See ya in a week!
    Randy, I am happy for you on one foot. and sad for you on the other. I bet you stood out side buy you mail, tapping your foot for, like 14 days. one thing is good. at least it got there before you left. right. I bet when you get home, all will be well, and you will cut out something to blow us away. I will be impatiantly waiting. ( i know spelling) your friend Evie
      All right Randy. I envy you. You'll probably have a hard time sleeping until you get back and start making sawdust. Does this kinda remind you of when you were a kid waiting for Santa? Be sure to let us know how everything works. Maybe I'll have to drive up sometime and check it out.
      Good luck
      Mike
        Put the stand, light, & DW-788 together today. Waxed the table, & cut some easy patterns I had out of a John Nelson pattern book. It seems like a pretty sweet saw. I noticed when I squared the blade to the table it was one notch from the O setting. Also had trouble clamping the blade in the bottom clamp almost like the blade clamps are too far apart. But when I finally got it clamped on both the top & bottom it sure did cut nice. Also when bolting the saw to the stand it pulls the pin from the rear of the table. After loosening the bolts & repinning it, it pulled loose again so just left it. I hope to practice a lot as I am not a very good scrollsawer but I am working fulltime & carving duck, loon, & fish decoys. The scrolling is a nice change of pace, but I have much to learn & am sure thankful for these various forums & the excellent advice I receive from all of you. Thank you very much! Will report back more as I go.
          Hi Randy
          I'd like to see some pictures of your decoys.
          MinotBob
          Makita MSJ-401
          Universal Tools:
          Remember you only really need 2 tools: WD-40 and Duct Tape. If it doesn't move and should, use WD-40. If it moves and shouldn't, use the Duct Tape
            Today, 08:57 AM
          • Dan A
            by Dan A
            Today, 06:33 AM
            Reply to Another Celtic cross
            Yesterday, 09:47 PM
          • Harry
            Reply to Toy jeeps
            by Harry
            Hi Jim.
            sure you...
            Yesterday, 01:18 PM
          • jim_mex
            Reply to Toy jeeps
            by jim_mex
            Yesterday, 10:15 AM
