Drilling with a Forstner bit
  • Drilling with a Forstner bit
    When drilling with a Forstner bit what speed would I use on my drill press? Drilling a 1/2" hole. The speeds are 620, 1100, 1720, 2340 and 3100 RPM. This is a fairly thick piece of Pine about 1-3/4”.
    Thanks,
    -Bill
    -Bill
    I typed in forestner drill bit speed chart and there are a number of sites listed . Hope this helps
    Smitty
    Smitty
    Dewalt 788
      Bill, The rule of thumb is the bigger the hole the slower the speed, in regards to your question and according to a chart I down loaded the correct speed for a 1/2 forstner bit drilling thru pine is 2400rpm.
      Here is a direct link to see for yourself.
      http://www.ibiblio.org/twa/info/drillSpeedChart.pdf
      Bill
      DeWalt 788
      aut viam inveniam aut faciam
        Thanks
        Thanks, guys, I down loaded that chart and it will go on the wall next to my drill press.
        Bill, that chart covers about everything on drilling.
        -Bill
        -Bill
          Hey - I paid a couple of bucks for that same chart before the internet became so prolific. The wonders of modern technology!
          Dan
          • Linda In Phoenix
            by Linda In Phoenix
            New toys sometimes become tools we can use, and other times they simply are tools toward expanding our horizons and being there when an idea pops into our heads. Let us know what you try the Ortur on and how it does. I'm sincerely curious. Also....why did you choose Amazon vs the other vendors...
            Yesterday, 11:47 PM
            What is it?
            Bruce was bored and made this. What is it?...
            Yesterday, 10:57 PM
            Reply to First you need to make a mess
            It was a challenge that’s for sure. I didn’t start anything until I was all finished. It’s nice to have a clean area to work in! My biggest challenge was all those pieces of scrap wood that I just might need “someday.” They burned well in my son’s woodstove. And I did get through all the patterns....
            Yesterday, 10:54 PM
          • tgiro01
            by tgiro01
            Wow - Betty, what do you charge. I have things to do and I'm in the process of cleaning my shop, just to have room to do it. My problem is that I get the work bench cleared and then start working on projects again. I really need to do the workbench last.
            Yesterday, 10:05 PM
          • tgiro01
            by tgiro01
            I ordered and received the ORTUR Laser Master 2 from Amazon, the but haven't had a chance to even get it out of the box. Too much going
            on right now. I got the 20 watt version, which is supposed to be good for cutting, but I don't think I'll be doing much of that. There will be a learning curve...
            Yesterday, 09:57 PM
