Good evening everyone! I have a dilemma (when don't I??). I'm trying to make the wooden padlock from Steve Good's site. You need to scroll about half way down the page to see it. I'm ok with the lock it's the key that's kicking my fanny!! I can't get the slots cut in it!! Can anyone tell me how the heck to do this?? Thanks so much for your help!!!
How do you cut slots in a dowel??
The "Key" (no pun intended) is to hold it securely and safely!"Still Montana Mike"
I have made a few locks and make my keys from 1/4" dowel. I put a 0 clearance table on my saw and just eyeball my slot, I can see that a V block would make this easer but i dont use one, and i cut a bit deeper than i need then sand it down square so you can drill the hole in the end of the key. I put in a picture of my last lock I dont have a close up of the keyAttached FilesWHEN LIFE
GIVES YOU HANDS
MAKE HANDMADESTAN
Hey Stan, love your lock!! Is that in one of the books on locks?? I have one of them but don't recall seeing it. Could you tell me where I might buy this pattern?? I hope someone can post some pictures of the v block so I understand.... maybe it's a woman thing?!?! Thanks so much!!Cathy in NE
The lock is my own design inside and out and unfortunatly I dont have a pattern as i just drew it on the wood and cut it I have a lot of people asking for a pattern and im just not that good at machanical drawing. As far as the V block goes heres a quick drawing of one from the end and should be about 3-4" long hope that helpsAttached FilesWHEN LIFE
GIVES YOU HANDS
MAKE HANDMADESTAN
You can also make one of Steve Good coin cutting jigs. You will also find the jigs handy for other projects as well, like 3D itemsMay the wind at you back .....
Not be from Lunch.
Oily's Gallery
Here ya go Cathy. Make up different size blocks for different projects.
Hold it flat to the table when you tighten the bolts so it doesn't wobble.Attached FilesMay the wind at you back .....
Not be from Lunch.
Oily's Gallery
Ok, I think I'm starting to get it now!! Can you believe this group!! Always willing to help! Stan, if you ever get a pattern created for the lock, let me know. I will be the first one in line to purchase it!! Thanks everyone you're all the greatest!!!Cathy in NE
If you take a scrap of wood and drill a horizontal hole in it the same size as the dowel, you can insert the dowel.
On the end of the block you can cut a slot. This will cut into the dowel.
It is not a bad jig because you can repeat the process and get consistant results.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Originally posted by CanadianScroller View PostIf you take a scrap of wood and drill a horizontal hole in it the same size as the dowel, you can insert the dowel.
It is not a bad jig because you can repeat the process and get consistant results.-- Rick --
by John SmithI've used 1/4 and 1/8" blades from different sources with good results. I use carbon fiber blade blocks so I can put the blade in the middle of the blocks. You have to "tune" the blade for your specific saw. Several videos on YouTube on how to tune band saw blades.
If you google...Yesterday, 09:57 PM -
...Yesterday, 07:31 PM -
by John Smiththanks Carole. I used the band saw with a 1/8" blade - not much different than the scroller but I have to use other methods to do the insides of the letters where the band saw can't reach. All the while, WISHING I had a scroll saw. and now, that I've got one, I'll be venturing back into dimensional...07-01-2022, 07:21 PM
by handibunnyVery impressive work, John. I like the tooled leather look, the detailed calligraphy, and especially the rendition of the brushes and other tools that you use for your craft. It will be interesting to see how you incorporate the scroll saw into your work, and the opportunities it provides you.07-01-2022, 06:31 PM
