is it common to have jagged edges when cutting a sharp V like grass in a wild life patttern as i am using 1/4 bb using a p-20 at medium speed thanks jack from saskatchewan
jagged edges
Hmmm you have to define jagged edges.
If the lines are jagged it could be that the blade is somewhat loose.
The blade could bounce a little then on the up and down stroke.
A tighter blade and a slower speed would correct this.
If the wood is splintering you could use a backer board or a reverse tooth or crown tooth blade.
If the wood is not being held tight enough to the table, that could cause jagged lines too.
You may want to cut two pieces of wood at the same time to gain better control over the wood.
Hope this helpsCAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Dale gave some excellent tips.
But I don't think you mentioned if you were using a flat blade or a spiral. A flat blade will give a cleaner and smoother edge than a spiral blade.
Its splintering at the top of the grass blade? like at the very point? When the wood is cut down to a sharp point, sometimes that can happen if you are making your cuts for both sides towards the point. I cut shapes like a blade of grass by cutting up one side, make a quick loop in the waste area, and cut down the opposite side of the blade of grass, so all of my cutting, or, i should say, my keeper part (this being the blade of grass), is on the right side of the blade as i cut, and thats with a flat blade.
Im not quite sure if I'm understanding the problem or not, but I hope that helped some, if not, Im sorry. DaleDale w/ yella saws
Mike, thanks for telling us how to determine when a reverse tooth blade is in upside down. I use to put the blade in and watch where the dust went, if it was on top of my cut I knew the blade was in upside down, now I can check the teeth, gonna make putting the blade in the right way easier.
Thanks again
MarshaLIFE'S SHORT, USE IT WELL
Glad you got it figured out. Isn't this forum handy? Without it, I wouldn't be scrolling.
Mike
Jack and Marsha, you're both welcome.Last edited by Minnesota scroller; 07-19-2006, 08:51 AM.
Reply to Question about tilting head sawsby hotshotI'll talk about this specific "slice" of your question. Most Tilting head saws do come from the same Taiwan factory, except Excalibur. So what happened with Excalibur was . . . General got bought by a Chinese investor, some China/Taiwan drama ensued, EX manufacturing moved to China. That...
Channel: Welcome Members
Today, 04:41 PM -
Reply to Basket C15Did this thread get hacked? That is a very strange sidetrack from KyivWorkshop.Today, 04:21 PM
Reply to Question about tilting head sawsby handibunnyIt doesn’t matter whether the saw table tilts or the saw arm tilts. Either can be used for any project cut at an angle, and there’s a learning curve for each.
I actually prefer the tilting table because the blade remains vertical. I find that at really steep angles, like 40 or 45 degrees,...-
Today, 02:10 PM -
by will8989This is the tapestry I found in the cedar chest. We can’t identify where the pictures are from. Two among many. I also forgot to mention dad was also in the army Fife and Drum Corps and also played with a big band when he was discharged. Have to find that info....
Today, 12:34 PM -
Reply to Bruce doing greatby will8989What a morning. The therapists were quite pleased with what he could do. He took the wrap off today and he can walk with the walker with very little pain. It’s getting the leg completely straight that is hard to do. It’s when his brother stopped in that things went off rails. Rolf, we are talking...
Today, 12:19 PM -
