Birdbath finally done and up
  • Birdbath finally done and up
    Finally warmed up enough outside to install the bird bath from a few issues back pattern. I found out the pattern had some "errors" after I started so simply modified it as I went.
    Cut out of exterior grade plywood, sprayed with primer and exterior white paint. This one took me about 2 1/2 hours total time, but I'm sure the next will be speedier as I have the actual dimensions in hand now.
    I also bought the companion bird feeder pattern. That one still needs to be primed and painted but thought I'd show it off now as well. 25' tape for scale, this one's "big" (about 10" openings!), about 3 1/2 hours into it so far.
    D. Platt
    Well done! I remember that issue, it never made it home with me! It was in my truck and one of my fishing/woodworking buddies latched onto it!
    Guess he's had it long enough. lol
    Bill
    Bill
    DeWalt 788
    aut viam inveniam aut faciam
      Bearfretworks,
      A .pdf file was posted on the forum with the correction for the side of the bird bath. I've attached it to save you the trouble of searching for it.
      Bruce
      Victorian Birdbath Side rev.pdf
      Bruce
      visit sometime
      Hawk 220VS, Delta 40-570
        Great job on those Bear! I think my first issue of SSW had one of those in it (can't be positive, too many damaged braincells, hehehe).
        Kevin
        Kevin
        Scrollsaw Patterns Online
          Good job on both pieces.
          Bill
          Delta P-20
            those did turn out nice. I would like to try the bird house feeder. its on my list. hope mine turns out as nice as yours did. your friend Evie
              Sorry Evie, but no way will it turn out as nice as mine. I'm positive it will be BETTER!
              Thanks for the kind words folks. I'll post a pic of the feeder when it is painted and installed - probalby this fall
              D. Platt
                Reply to My computer issues.
                I clean it up and stuff regularly. If I do a lot of typing, spreadsheets, etc., I use the computer as it’s faster for me but take the tablet to shows and markets to post from there. I also use my rapid resizer program on the tablet when I want to change a pattern and am downstairs. I really need a...
                Yesterday, 11:16 PM
              • Linda In Phoenix
                by Linda In Phoenix
                Yesterday, 05:55 PM
                Linda,
                Quote, I kept my old computer even though it was barely alive simply due to one particular program...Picassa by Google...which they removed from the market years ago. It worked like a combo photo and editing program but easier. It could take a photo and change it to a line drawing beautifully...
                Yesterday, 08:41 AM
              • RJweb
                by RJweb
                Buy an apple and keep the computer dr away, RJ...
                Yesterday, 08:39 AM
                Reply to New turning tools
                Thanks for posting Carole, Depending on what other time consuming distractions I have I might just have to do a wavy bowl.
                Also for reminding me that I have your books on my shelf for inspiration!!
                This will also be the first time I use the Excalibur to cut the rings instead of fighting...
                Yesterday, 08:27 AM
