Lanterns
  • Lanterns
    I am making the lanterns from this month's SSW, only I want to make them candle holders instead of electric lights. What safety precautions do I need to use? I suspect the glass votive candles are the safest candles, but I'm afraid of fire with the rice paper. Do I need to use a layer of sand in the bottom or anything like that? Any advice is deeply appreciated Thanks!
    You cannot have anything on the top of the lantern, you would be amazed at how much heat even a little tea light will produce.
    When I have made candle sconces I have used a forstner bit to drill a hole for a tea light.
    If you are using votives I would recommend using a glass holder.
    Tea lights on the otherhand usually come in small aluminum or plastic holders.
    I have used plain printer paper in lanterns before that I have rubbed with mineral oil. I wouldnt worry about using sand. That could get messy.
    The real safety precaution here is to not leave the candles unattended.
    I did pick up some solid state LED candles that run on batteries. They look quite good when illuminating through paper. You may want to try this apporach too.
      Hey, I didn't know about the LED candles I want to make these for my son for his birthday, he is crazy about candles. Thanks for the excellent advice!
