Recently I have been stack cutting 1/4" BB ply. Things work fine when I stack 2 pieces. When I stack 3 I start having trouble with grab and hammer. If I stack 4 it's not worth trying to cut.
After reading through lots of posts here, I have looked at blade size, tight corners, two handed pressure, blade tension and feed rate. I can think of times when each of these have given me trouble, but I don't think any of them is the problem in this case.
I think my blade isn't clearing the sawdust from the kerf and the buildup causes the blade to grab the work. I decided this must be the problem when I noticed sawdust caked against the side of pieces I removed from the work. I only see this on the 3/4" and 1" stacks.
Does this make sense to anyone else? Can anyone point me to anything else I might be missing?
I'm having trouble believing that my Delta scrollsaw is really limited to 1/2" thick cutting or less.
Thanks in advance.
Thanks in advance.
