This is a picture of the project that hubby and I were working on to hide that we were actually working on two at the same time (the other one was the housewarming gift). They were lots of fun and we had a good time working together. We are now working on our own projects, and Craig starts doubling up on the college classes this month so he can finish this year, so no more projects together for a while.
Second hubby and me project
That's both unusual and lovely. You and your hubby are so talented.
Did you cut the rainbow bands individually? You've done a wonderful job on them.
Nicely done,
You did a great job on the miters for the frame! Not easy to have tight fitting miters on 4 corners, much less on 12@ 15° each.
The scrolling is awesome too, those birds and foliage details must have been fun to cut.
I also am curious to know if the sun's 'colours' were cut separately or if you did it in one piece, and if so how did you avoid colour bleeding?
My only negative comment is that the frame seems to have some 'nibs' in the finish; perhaps a little more sanding was required between coats, or maybe a finer final sanding ? (nothing that can't be corrected)
But overall : Congrats, and keep doing whatever you do, it's nice
Respectfully,
Marcelhttp://marleb.com
Thanks everyone! The sky was cut out of one piece. I drew the half-circles then cut the strips, then painted, then glued each together and on a back board.
Marcel-you are right about the finish. By the time we were almost done with the two projects, we were so tired of doing them, that we just didnt sand anymore. Because this one was just for us we didnt worry as much about the finish as we should have.
Also, found out that hubby and Ihave different views on what constitutes "good enough" and "finished"
But we stayed married, and had a good time
Carrie
by cwmageeI have the Pegas replacement table for my EX21. It was the best investment that I made. The best part is they eliminated the useless vacuum holes and reduced the size of the blade hole as well. Another benefit was the table stiffened the EX21 frame eliminating much of resonant vibration. It is a much...
Today, 09:45 PM -
Reply to Shawl pinsby KarlBThat's what I was wondering Betty: If these would work (larger) for hair?
Karl...-
Today, 04:47 PM -
Reply to Shawl pinsby RJwebWho said being bald isn’t a plus, RJ...
Today, 01:18 PM -
by will8989The perfect solution when I need a wider top on my Hegner. A magnetic sheet! I decided not to get the Pegas as the only reason was for the wider top and the top feed blade. After 19 years, my Hegner is still running like new and I couldn’t justify the expense. It was a “want” and not a “need”....
Today, 12:27 PM -
Reply to Shawl pinsby will8989Good idea Scott. Also, my daughter has long, curly hair. She twists it up and around and sticks a pencil in to hold it. I also stick a dowel in my hair when working and my hair gets in my way and I twist it up. The one in this picture would perfect for thick hair.
Today, 12:19 PM -
