Hi,
(Bob Delete this if I infringe any rules, as I'm not certain)
I told you a wile ago that my first project might bring me a commission.
Here is the sketch of what I came up with by combining 2 patterns.
It will be 21 x 33, which should make it real interesting to do
as one of my first 10 projects.
I'm thinking of using 1/4" & 3/4" BB:
- Sandwiching the 2 and cutting out the outside form of the plaque
- Painting the surface of the 3/4" black flat enamel with a primer sealer under it.
- Scrolling the 1/4" with a spiral blade since I won't be able to turn every which way
- Gluing the 2 pieces together
- Routing an edge to the whole thing
- Maybe staining, not sure but most likely
- Finishing with a spraying of multiple coats of SPAR Urethane
- Price quoted: between $200-$250 CDN (Does it sound right?)
Any suggestions before I start?
Regards,
Marcel
Regards,
Marcel
