Does anyone else have a problem with the fretwork frame pattern in the summer 2006 issue? I made a copy of the pattern (main frame outline.)I started to cut it out and noticed that the left side did not match the right. It looked like the pattern had moved while I was scanning it. Especially dead center on the bottom half. an example is a half round shape on the left half is an oblong shape on the right. several of these errors. Anyhow I was going to calibate my scanner but noticed it is on my original!
The pullout pattern for this project has several mistakes on the one I have and it is really noticable and cannot be used! It appears it is only on this piece of the pattern, but that is the main part that is what everyone would examine. It's a shame since I really liked this one. Do others have this problem?
I know this one is fretwork, but I also wish it had been done as a line-art pattern. most fretwork picture patterns you can use a spiral blade and it won't show if you go off a line a little. But this is more like a scrolled pattern than a fretwork picture and requires more control. If it had lines in the pattern I personally would be able to control my cuts better (just seems weird to cut out the white portion of the pattern...just my opinion.)
Ed B.
btw...also love the lamps pat. in this issue!!!
Ed B.
