Thanks for the info
  • Thanks for the info
    I thank everyone for their opinions and advice. I decided to buy the ex30, it sure didn't look this big in the store. It was pretty easy to set up, and cuts really nice right out of the box. I'm not going to worry about the arm lift, after reading your replys it makes more sense to make my own. Thanks again
    Now the real fun begins!
    Tomlock
    It's good to know you're finding the forum useful . I'm sure you'll get years of happy productivity from your new saw.
    Although the saw may appear to be perfectly set up, can I suggest you check that the table is square to the blade? You can use either a protractor or an engineers square to do this, or even a largish block of square waste wood; simply make a cut into the wood, then invert it and hold it against the blade - if the cut lines up with the blade, the table is square.
    It might sound quite trivial, but you'd be surprised at the difference that even ½° out of square will make.
    Gill
    • Sandy Oaks
      Teach - Learn
      by Sandy Oaks
      This gallery has 2 photos.
      Today, 12:13 PM
    • Sandy Oaks
      by Sandy Oaks
      Today, 11:22 AM
      Today, 09:54 AM
      Today, 09:51 AM
      Today, 09:42 AM
