Where can I buy a fludder/flapper wheel?
Flapper Wheel
Livy--not sure what you really want. There all kinds of "flutter" and "flapper" wheels out there. Some require their own motor, but others will fit a drill press and/or power drill. Suggest you look at the sites listed to the left under "Other Great Sites" and click on "Retailers". Many of those listed--Rockler, Woodworker's Supply, Klingspore's, etc offer sanding wheels. Locally, you can usually find one at either Lowe's or Home Depot. Sometimes Sears will have one. Hope this helps.
MoonOld Mooner
Hi Livy,
Like Mooner said try Rockler or Grizzly.com or check out this site
http://www.citools.com/abrasives.htm
BillBill
DeWalt 788
aut viam inveniam aut faciam
Sanding wheels
Hi
If you are looking for a great sanding "flap wheel" have a look at the "BlowFly" - it's only just come onto the market - www.piricdesign.com.au an Aussie product!!!
Tony Ward
www.tonyward.org
Flapper Wheel
I'm not sure that you want to use a flapper wheel to clean out the inside of fretwork. You will lose all your sharp edges as the flapper wheel will tend to "round over" anything with corners. If you use a reverse tooth blade you should wind up with a pretty clean cut on both sides that will require only minimal light sanding on the back side of the work to remove any "fuzzies" that remain. Flapper wheels are generally used to soften the look of a piece on which you don't want "hard" edges. You generally want nice crisp edges on fretwork. Then again....maybe I don't totally understand exactly what you're wanting to do and I'm giving you poor advice!!!But my heart's in the right place.
by John SmithI've used 1/4 and 1/8" blades from different sources with good results. I use carbon fiber blade blocks so I can put the blade in the middle of the blocks. You have to "tune" the blade for your specific saw. Several videos on YouTube on how to tune band saw blades.
If you google...Yesterday, 09:57 PM -
...Yesterday, 07:31 PM -
by John Smiththanks Carole. I used the band saw with a 1/8" blade - not much different than the scroller but I have to use other methods to do the insides of the letters where the band saw can't reach. All the while, WISHING I had a scroll saw. and now, that I've got one, I'll be venturing back into dimensional...07-01-2022, 07:21 PM
by handibunnyVery impressive work, John. I like the tooled leather look, the detailed calligraphy, and especially the rendition of the brushes and other tools that you use for your craft. It will be interesting to see how you incorporate the scroll saw into your work, and the opportunities it provides you.07-01-2022, 06:31 PM
