Scrollers, I'm reading thru my plans for the Manchester Hall Clock before starting one for the first time. For those of you that have already built one, I have a few questions:
1. The clock face overlay can be made from brass or contrasting 1/16" wood. Any experiences that would lean one way or the other? I'm wondering if the brass overlay would be too much with the brass dial/bezel.
2. The overlay is 1/4" smaller than the backer, which would leave 1/8" of the backer exposed around the outside. Would this look better if the overlay filled the space (in other words, make it the same size as the backer) or does that 1/8" of contrast look better?
3. In attaching the sections together, is it enough to screw it together from one direction only, or would you recommend fastening from both directions for strength?
Trying to avoid problems the first time thru. Always nice when you can talk to someone that has already been there. Thanx for your help.
Bruce
Bruce
