I'm going to pick up a few 1 7/16" clocks and a forstner bit from Sloan's or Wildwood to incorporate some clocks into my next projects. Do you have to use 3/4" or will 1/4" with a stand work?
You can use 1/4, but the back of the clock insert may stick out the back of the project, depending on the company you order them from. I think most are 1/4 deep,or 5/16 inch deep. 1/2 inch thick wood would be my choice to use, but it would also depend on the pattern. http://www.klockit.com/products/dept-27__sku-OOOOO.html Check out these clocks as well. Klockit has a huge variety of clock making supplies,and on their site they do a much nicer job then the others of describing the hole requirements for mounting, both diameter, and depth. To answer your question in a simple answer...... No, you dont HAVE to use 3/4 thick wood. dale
I have made well over 100 mini clocks and I always used 1/4" wood. The movements were from Wildwood and they were pretty well flush with the back of the wood. I even used 1/4" for the base's . Great way to use up some odds and ends of left over wood from when making larger clocks.
I generally make a batch of about 25 when I go at it but I am all out of stock again. They sell real good at $25.00 each around here. I stack saw 3 at a time in hardwood or 4 at a time with softer woods.
I like to get the quantity discounts from Wildwood when ordering those little movements.
I know some like to use 3/8" or even 1/2" for them but I have never had a problem with just 1/4" wood.
W.Y.
Glad you got it, got it set up and working Tony. Fortunately I have a DH who is much more technical on builds like that so I let him put it together for me. I knew he would get it built much faster and with much less frustration then I could have.
Thanks - To make the box joints I used a 1/2" straight bit and my Incra jig. I used the little right angle sled that comes with the Incra fence, but now that I have the miter slot, I'll be getting or building a good coping sled....
I cleaned some space on my workbench to set this thing up and then had to clean some more space. I read about the 54X45CM size, but I guess I wasn't really thinking about how big it is. I put an 18 inch ruler in for scale in the "built" picture.
