Dremel 1680 Owners: FYI
  • Dremel 1680 Owners: FYI
    Hi Friends,
    Before I decided to make a sandbox for my Dremel 1680, I thought it wise to check with Dremel to see how much weight the 16500 stand (came bundled with my 1680 saw) can safely hold. The technician in the company told me the stand is designed to hold 200 pounds. My guesstimate is that the sandbox will hold about 50 pounds of sand, and the 1680 weighs 45, I think.
    Just so you’ll know that the 16500 stand should be well able to hold the sandbox’s weight safely.
    Ann
  • Gary beasley
    Reply to Cutting guide for straight cut on a scroolsaw
    by Gary beasley
    Cutting a straight line I get it started then plant my thumb at the side of the piece and use that to stabilize the cutting path, a bit like the pin you would use on a bandsaw when resawing old style.
    Today, 02:34 PM
    Wood supply
    We went to Groff & Groff yesterday. Purple Heart wood is stuck on a boat somewhere. They said imported exotic and hardwoods are stuck on boats. So if you see a wood you need, grab it while you can.
    Today, 09:58 AM
    Reply to My beauties
    He has 4 of the long ones, but we have other sizes that he uses for clamping up his cheese board slicers, another good seller. They go for $35, left over wood from dough board. On late shift yesterday because I took a 2 hour nap around 7. Off to the saw! I have 8 days of shows in 2 weekends! And one...
    Today, 09:49 AM
  • RJweb
    by RJweb
    The boards and baskets are beautiful, but maybe buy Bruce some more clamps, also I see you are on the night shift again, RJ...
    Today, 09:28 AM
    What Carole said. The lips are 1 1/2”, holds the board to the counter and keeps the flour from going off the back. After gluing them to the board, he drilled stainless screws through the lip into the board and made plugs to fill the holes. The board is 3/4” thick. Since he only has 4 large Bessy...
    Today, 01:20 AM
