How to glue a small bridge that broke?
  • How to glue a small bridge that broke?
    I'm not talking about a replica of the Brooklyn Bridge. I bought that a few years ago... I made a pattern for a portrait of my dad and unfortunately left too flimsy of a bridge between his face and where I cut out for his eye. The too thin bridge broke.
    If I use Aleen's glue to connect this small bridge together, should it hold? A tip I saw said to do gluing like this on wax paper so it doesn't stick to the surface. If I glue, should it be before or after finishing with Watco Danish Oil?
    My other alternative is to attach it to the felt or backboard as a floater. Which way would you do it?
    Harris
    Yes it will hold very well -- try applying it with a tooth pick - and apply it before you finish it..
    Sharon
      I like to hold the pieces together by pinning them to a board till they dry.
      The wax paper is a good idea.
      If you stain first then the glue wont change the stain colour.
      Try to keep the edges clear of stain to allow the glue to soak into the pores.
        Glue first then stain gets my vote. You always get better bonding wood to wood. Also you can use yellow carpenter's glue for this. But if you stain first then use the Aileens
        John T.
        • alexscrollsaw
          Firefighter
          by alexscrollsaw
          Firefighter - my latest
          Firefighter pattern
          Yesterday, 08:27 AM
          Reply to Hegner
          The Hegner like some other saws have a sweet spot or not so sweet spot where they may vibrate. I know they need to have a solid footing.
          When we were younger (2005) we used to bring our saws to our club meeting in an old barn with wooden floors. The seasoned scrollers all had Hegners. The rest...
          Yesterday, 07:46 AM
          Reply to Eccentric adjustment
          I assume you are talking about changing the stroke length. Looking at the manual it says you can shorten it for cutting thin wood and or metal. I have never known anyone that did that. We have several Hegner owners in our club. I am not one of them.
          Yesterday, 07:37 AM
        • Dave56
          by Dave56
          Has anyone made any adjustments to the eccentric or connectors on the Hegner M22
          03-30-2023, 04:59 PM
        • Dave56
          Reply to Hegner
          by Dave56
          Has anyone replaced the eccentric on the Hegner scroll saw or made any adjustments to this part.
          I bought an used Hegner m22 and it vibrates at about 3/4 speed. Maybe I'm just over thinking this problem, last year I purchased a multi cut 3/25 inch Hegner it is a single speed and it runs like a...
          03-30-2023, 04:50 PM
