Ok, Here's A Dumb One. I Would Like To Know What Tool Is Used In Making The Big Clocks To Bevel The Larger Pieces Like The Walls. A Table Saw Might Take A Finger And I Cant See Something Like A Sphere Being Cut Precisely On A Scroll Saw Either. One More, Do Most Scrollers Really Use A Mask When Cutting , I Dont And I'm Beginning To Wonder If I Should. Tks, Rain Man
Bevel Cuts
By all means try to wear a dust mask. The scrollsaw produces fine dust not large particles like a tablesaw. Just look at the size of the blades used should tell you that. As far as makinging bevels or angles in pieces like walls of a large clock. Some people like to do this on a belt sander such as thisSome use the popular 4" belt and 6" disc sander. Others like myself like to do them on my tablesaw with a sliding sled setup or I happen to own a dubby cutoff system. Doing it on a tablesaw for me is very accurate and the thing it does require is a holddown clamp so your hands do not get near the blade. With the sander I like to set the table to the degree I want and clamp a straight edge to the table 90 degress with the table so all you have to do is slide the piece next to the straight edge and sand away. Either method works well.
Just to mention it again air quality in the shop. Wear a dust mask and enjoy your hobby safely.John T.
Rain Man, if you wear glasses while scrolling take them off and look at the lens after you have scrolled for a while. That is what you are breathing. I always wear safety glasses and dust mask. I purchased the mask from www.westernsafety.com, it will not fog your glasses. MickMick, - Delta P-20
Why do you have sawdust sticking to your eye glasses? I use anti-static wipes bought at office supply stores on my magnifying glasses and specks and get no static cling. I agree with your example however. Small particles are not as obvious as the stuff that falls on the floor. The "tip" in the latest issue of "The Magazine" about using a filter on a fan is a good one and one i have used for years in my shop.
MoonOld Mooner
Reply to I decided I needed a challengeby handibunnyBack in my days of collecting antique pottery, I used to carry a a small blacklight unit to check for repairs that were invisible to the naked eye. I never knew that it could detect glue spots. That's a lot neater than using mineral spirits, or waiting until a sealer coat of shellac reveals missed...
Channel: Works in Process
Today, 06:22 AM -
Reply to My lucky day!by will8989Being a diet controlled type 2 diabetic, I check my glucose. Checked before my shot on Tuesday it was fine. Checked on Wednesday after a morning walk expecting to see less than 100 and about fainted when it read 158. Every check has been 150 or more since then. Started reading and yes, the shots can...
Yesterday, 10:37 PM -
Reply to I decided I needed a challengeby will8989Not yet Jim. The corners of the baskets to appear to be drawn by hand or just a bad copy. The price might go up. Thanks Linda. For some reason I really like doing layered baskets. And my customers like buying them. Bruce read a blacklight shows glue spots. Guess what he bought me from harbor freight...
Yesterday, 10:04 PM -
Reply to Need advice...by handibunnyJim, if all else fails, try this link://birchbarkstore.com/collections/tree-slices-log-rounds-slabs-tree-stumps
I've bought lovely aspen and Balm of Gilead rounds from this site to use for live edge bowls. The owner, Rene Guay (pronounced "Rainey") could probably fabricate something...-
Channel: Wood and Materials
Yesterday, 03:38 PM -
Reply to I decided I needed a challengeby Jim McDonaldI guess you whipped that challenge.
Beautiful work.-
Yesterday, 02:54 PM -
