You've mentioned that you use calenders, magazine covers, etc. for your jigsaw puzzles. Do you ever scan pictures in then print them out on 8.5x11 photo paper? Is there any reason this would be a problem?
Sure........No reason for a problem; just a bit different process. When I print from a computer, I use glossy photo paper. Regular 20-lb paper is often too thin to glue down smoothly. Also, I haven't found a reliable spray to protect computer-printed documents.
Wow - Betty, what do you charge. I have things to do and I'm in the process of cleaning my shop, just to have room to do it. My problem is that I get the work bench cleared and then start working on projects again. I really need to do the workbench last.
I ordered and received the ORTUR Laser Master 2 from Amazon, the but haven't had a chance to even get it out of the box. Too much going
on right now. I got the 20 watt version, which is supposed to be good for cutting, but I don't think I'll be doing much of that. There will be a learning curve...
